Comparing Wave Functions: Are \psi_{1} and \psi_{2} in the Same Quantum State?
The discussion centers on determining whether the wave functions \(\psi_{1}(x,y,z) = A\) and \(\psi_{2}(x,y,z) = e^{z}A\) represent the same quantum state. Participants conclude that both wave functions correspond to the same quantum state, emphasizing the importance of the relation between wave functions and quantum states. The correct mathematical representation involves using the coordinate basis, where \(|\psi_1 \rangle = \int d\vec{x}~ \psi_1(\vec{x}) |\vec{x}\rangle\), and demonstrating that \(\langle \vec{x}|\psi_1 \rangle = \langle\vec{x}|\psi_2 \rangle\).
  • Understanding of quantum mechanics and wave functions
  • Familiarity with the mathematical representation of quantum states
  • Knowledge of the coordinate basis in quantum mechanics
  • Basic proficiency in complex exponentials and their implications in wave functions
  • Study the mathematical framework of quantum states and wave functions
  • Learn about the implications of wave function normalization
  • Explore the concept of inner products in quantum mechanics
  • Investigate the role of complex exponentials in quantum wave functions
Students of quantum mechanics, physicists analyzing wave functions, and anyone interested in the mathematical foundations of quantum states.
Axiom17
To determine whether two wave functions, [itex]\psi_{1}[/itex] and [itex]\psi_{1}[/itex] correspond to the same quantum state of a particle.
Calculations (simplified):
[tex]\psi_{1}(x,y,z)=A[/tex]
[tex]\psi_{2}(x,y,z)=e^{z}A[/tex]
The two wave functions do correspond to the same quantum state. However I can't figure out the correct wording to explain this. At the moment I just have that "[itex]\psi_{1}[/itex] is equal to [itex]\psi_{2}[/itex] with respect to the independent variable [itex]z[/itex] in the term [itex]e^{z}[/itex]".
Hopefully that's correct, or at least it makes some sense.. sure there's probably a better (more correct) way to write it though. :shy:
You should use the relation of wavefunctions to quantum states. For instance in the coordinate basis [tex]|\vec{x}\rangle[/tex], we can write
[tex]|\psi_1 \rangle = \int d\vec{x}~ \psi_1(\vec{x}) |\vec{x}\rangle .[/tex]
Then one way to show that two wavefunctions describe the same state would be to show that
[tex]\langle \vec{x}|\psi_1 \rangle =\langle\vec{x}|\psi_2 \rangle[/tex]
Are you sure there is [tex]e^z[/tex] and not [tex]e^{iz}[/tex] in your problem? Just checking ...
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 26 ·
