Register to reply
Thermal Switch Design Project... need help fast!
by naevitar77
Tags: design, project, switch, thermal
Share this thread:
naevitar77
#1
Oct16-10, 04:05 PM
P: 3
There are three vertical metal strips (Steel, Aluminum, Steel) between two horizontal rigid bodies
alphaa = 12.5 E-6 /degF -- coefficient of thermal expansion
alphas = 6.6 E-6 /degF
Ea = 10 E6 psi -- Young's Modulus
Es = 30 E6 psi
The original dimensions of the switch are
ta = .0625 in -- thickness of aluminum
wa = .25 in -- width of aluminum
ts = .0625 in
ws = .125 in
L = 4 in -- length of all metals
With these dimensions, the switch will activate with a 180 degF temperature increase
By only changing the dimensions of the aluminum strip, I have to modify the switch to activate with 100 degF temperature increase
2. Relevant equations
δ = P*L/(E*A) + alpha*ΔT*L
Pcr = 4*pi^2*Ea*Ia / L^2 -- critical axial compressive load for the aluminum to buckle
Ia = wa*ta^3/12 -- minimum second moment of inertia
3. The attempt at a solution
I tried setting the deformation of the aluminum equal to that of the steel
δa = δs
Pa*L/(Ea*Aa) + alphaa*ΔT*L = Ps*L/(Es*As) + alphas*ΔT*L
from a free body diagram, I got Ps = -.5*Pa
Pa*L/(Ea*Aa) + alphaa*ΔT*L = -Pa*L/(2*Es*As) + alphas*ΔT*L
Pa*(1/(Ea*Aa) + 1/(2*Es*As)) = ΔT*(alphas - alphaa)
solving for Pa and simplifying using (1/a + 1/b)^-1 = ab/(a+b)
Pa = ΔT*(alphas - alphaa)*(2*Ea*Aa*Es*As / (Ea*Aa + 2*Es*As))
substituting Pcr = Pa
pi^2*Ea*wa*ta^3/(3*L^2) = ΔT*(alphas - alphaa)*(2*Ea*Aa*Es*As / (Ea*Aa + 2*Es*As))
now solving this for the temperature..
ΔT = pi^2*ta^2/(3*L^2) * (Ea*Aa + 2*Es*As)/(2*Es*As(alphas - alphaa))
when I plug in the variables for the 180 degF switch from above, I am getting
ΔT = -181.5 degF and I do not see anything wrong in my algebra; my units still come out to be degF.
Can someone tell me what I am doing wrong? Am I approaching this the right way?
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
nvn
#2
Oct17-10, 05:03 AM
Sci Advisor
HW Helper
P: 2,124
naevitar77: Excellent work, so far, except for one minor mistake. Pcr should be, Pcr = -4*Ea*Ia*(pi/L)^2. You erroneously omitted the negative sign here. Try it again.
By the way, numbers less than 1 should always have a zero before the decimal point. E.g., 0.25, not .25. See the international standard for writing units (ISO 31-0).
naevitar77
#3
Oct17-10, 11:54 AM
P: 3
Quote Quote by nvn View Post
The handout my professor passed out on this project defines Pcr without a negative sign. Why is it suppose to be negative?
nvn
#4
Oct17-10, 12:18 PM
Sci Advisor
HW Helper
P: 2,124
Pcr is negative because it is compressive force. Your professor listed the magnitude.
naevitar77
#5
Oct17-10, 12:56 PM
P: 3
That makes sense. Thank you so much nvn. You're a life saver!
Register to reply
Related Discussions
Feel really stupid. Need help. Thermal switch design problem. Engineering, Comp Sci, & Technology Homework 1
Thermal Design Liquid PVT Relationship Mechanical Engineering 3
Need help tounight for a design project im doing, involves a thermo switch (Statics) Engineering, Comp Sci, & Technology Homework 1
Difference between Thermal and Fast neutron in a reactor? High Energy, Nuclear, Particle Physics 4
Fast Talker Project Calculus & Beyond Homework 2
