New Reply
Perfectly elastic collision?
Share Thread Thread Tools
Oct17-10, 02:08 AM   #1
A package of mass m is released from rest at a warehouse loading dock and slides down a 3.0m high frictionless chute to a waiting truck. Unfortunately, the truck driver went on a break without having removed the previous package, of mass 2m, from the bottom of the chute.
Suppose the collision between the packages is perfectly elastic. To what height does the package of mass m rebound?
http://session.masteringphysics.com/...3/3/10.P42.jpg
2. Relevant equations
3. The attempt at a solution
So far I know that the velocity of mass m at the moment of impact is 2.6 m/s. I think I should be using the conservation of energy/momentum to solve for the final velocity of mass m. I then think I can use this velocity to solve for K, and use this to solve for the height from U=mgh. I just can't figure out how to solve the final velocities.
[tex]2.6m=mv_{1}_{f}+2mv_{2}_{f}[/tex]
[tex]\frac{1}{2}m(2.6)^2=\frac{1}{2}mv_{1}_{f}^2+mv_{2}_{f}^2[/tex]
Are these set up right? If so, how do I continue? As you can see my algebra skills may be lacking.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Oct17-10, 03:45 AM   #2
First of all I see that "m" appears everywhere. Can you simplify it ?
Oct17-10, 03:49 AM   #3
Your result of 2.6 m/s is wrong. You can calculate this with (final kinetic energy) = (initial potential energy), so (1/2)mv^2 = mgh
Apart from this your equations are correct. For a start you can divide them by m.
There are 2 ways of doing this. The first is to rearrange the first equation to get v_1 as a function of v_2, and then substitute this in the second equation.
A better way is to find the velocity of the center of mass, and compute all velocities in the reference frame of the center of mass. The equations become
[tex] 0 = mv_{1}_{f}+2mv_{2}_{f} [/tex]
(0 because it's the center of mass frame)
[tex] KE = \frac{1}{2}mv_{1}_{f}^2+mv_{2} _{f}^2 [/tex]
where KE is the initial kinetic energy in this frame
It's then easy to see that if (v1,v2) is a solution to these equations, so is (-v1,-v2)
Finally you have to transform the velocities back to the rest frame.
Oct17-10, 10:42 PM   #4
Quote by willem2 View Post
Oh crap. 2.6 is the speed of the objects after an inelastic collisions. I have been using the wrong number the whole time. Let me try it the right way... Is the velocity 7.67 m/s?
GOT IT! 33cm is the rebound height.
When I did finally get the correct FINAL velocity for the mass, it was -2.6. Is this just a coincidence that this is the same as the 2.6 that I thought was the initial velocity? Anyway, thank you!!!
New Reply
Thread Tools
Similar Threads for: Perfectly elastic collision?
Thread Forum Replies
perfectly elastic/inelastic collision Classical Physics 9
Perfectly elastic collision Introductory Physics Homework 3
Perfectly elastic collision Introductory Physics Homework 2
perfectly elastic collision Introductory Physics Homework 3
perfectly elastic collision Introductory Physics Homework 7
