Smooth covering map and smooth embedding
  • Context: Graduate
  • Thread starter Thread starter huyichen
    Map Smooth
The discussion centers on the smooth covering map F: S^2 -> R^4 defined by F(x,y) = (x^2 - y^2, xy, xz, yz) and its relationship with the smooth embedding of RP^2 into R^4. Participants clarify that the task is to demonstrate the existence of a map f: RP^2 -> R^4 such that f o p = F, where p is the smooth covering map from S^2 to RP^2. The key point is that F must be constant on the fibers of p, which simplifies the process of verifying that f is a smooth embedding.
  • Understanding of smooth manifolds and embeddings
  • Familiarity with covering maps and quotient spaces
  • Knowledge of Jacobian matrices and their role in determining smoothness
  • Basic concepts of projective spaces, specifically RP^2
  • Study the properties of smooth embeddings in differential topology
  • Learn about the construction and implications of covering maps
  • Investigate the role of the Jacobian matrix in smooth mappings
  • Explore the relationship between S^2 and RP^2 in the context of topology
Mathematicians, particularly those specializing in differential geometry and topology, as well as students seeking to understand the concepts of smooth maps and embeddings in higher-dimensional spaces.
huyichen
Now F:S^2->R^4 is a map of the following form:
F(x,y)=(x^2-y^2,xy,xz,yz)
now using the smooth covering map p:S^2->RP^2, p is the composition of inclusion map i:S^2->R^3 and the quotient map q:R^3\{0}->RP^2. show that F descends to a smooth embedding of RP^2 into R^4.
Is the problem asked to show that F。p^(-1) is a smooth embedding? I am confused, and if it is the case, then how should we compute the Jacobian matrix for F。p^(-1)?
Essentially, yes, but notice that p^-1 is ill defined. Instead, you must show that there exists a map f: RP^2-->R^4 such that f o p = F (and that it is a smooth embedding). Observe that this only means checking that F is constant on the fibers of p.
  • · Replies 20 ·
