What is the process for finding max, min, and avg temp for a given function?
  • Thread starter Thread starter ACLerok
    Max
The discussion revolves around a function representing outdoor temperature over a specific time period, where participants are tasked with finding the maximum, minimum, and average temperatures from the function T(t)=50+14sin([pi*t]/12) for the hours between 9am and 9pm. The original poster expresses uncertainty about the process of deriving the function to find extrema and the integration needed for calculating the average temperature.
  • Participants discuss the necessity of deriving the function to find maximum and minimum temperatures, questioning what steps to take after obtaining the derivative. Some suggest setting the derivative to zero to find critical points, while others propose using graphical methods to identify extrema. The average temperature calculation through integration is also mentioned, with questions about the integration process itself.
The conversation is ongoing, with various approaches being explored. Some participants offer insights into using the derivative to find extrema, while others suggest alternative methods, such as evaluating the function's maximum and minimum values based on the sine function's properties. There is no clear consensus yet, as participants are still clarifying their understanding and exploring different interpretations of the problem.
There is some confusion regarding the time frame for the problem, as the original poster mentions 9am to 9pm, while others point out that the function is defined in terms of hours after 9pm. Additionally, there are constraints regarding the instructor's preferences against using graphical methods.
ACLerok
Alright, I am given a function that approximates the outdoor temperature on a particular day where t is the time in hours after 9pm.
I am to find the max and min temps and average temps on tha day between 9am - 9pm. I know i am supposed to derive the given function to find the max and min temps but once i have the derived function, what am i supposed to do with it? The instructor didn't go in depth on how we are supposed to do it. Also, i know that to find the average temp you are supposed to integrate it and do
T_avg=(1/12)integral(0-12)T(t)dt
Is that all there is to it for finding the average temp?
Thanks.
9 pm-9am ? t is the time in hours after 9 pm ...
thats the way it says on the sheet. anyone else have any input?
To answer the first part of your question, think about what you are doing when you derive a function: you are finding a general equation in terms of a variable for the slope of the original function. What can you do with this equation to find the min/max values? (Huge hint: what is the slope equal to at those points?). Don't forget to verify to see which result is max and which is min.
I guess the slope would be zero at those points. so i just compute the derivative of T(t)=50+14sin([pi*t]/12) and plug in 0 for t to find the max and mins?
No. You do not want to know the temp. at time=0. Remember, the derived equation represents the slope, and as you said yourself, the slope is zero at max/min points.
Why don't you draw the graph to find the max and min?
Average has to do the integration.
alright.. I am guessing I'm supposed to derive the T(t) equation, set that equal to 0 and find the high and low times and then plug those times back in the original equation? Thakns for all your help.
PS this is prolly wrong. as for graphing it, my teacher would prefer us not to.
sometimes it's not necessary to use calculus.
|sin(alpha)|< or = 1 => the maxium value for this function is sin(alpha)=1
and the minimum => sin(alpha)=-1from here you can use these value to obtain: for "T"max, T(t)= 50+14=64 and for "T"min, T(t)=50-14 =36.
wisky40
ACLerok,
wisky40's way is the fastest to obtain the min. but derivative won't help you to find the max. from the graph i drew,the max happens when t is 6 hours after 9pm, means it happens at 3 am which is out of the range of the question which states from 9 am-9pm. i think for this period, the max is just 50 which happens at t = 12 and 24 corresponds to 9 am and 9 pm respectively.
real quick. how would i evaluate the integral of sin[(pi*x)/12]?
is it just -cos[(pi*t)/12] ?
No. It is
[tex] \frac{-cos\frac{\pi t}{12}}{\frac{\pi}{12}}[/tex]
12K
