New Reply
finding AC voltage across Resistor
Share Thread
Oct19-10, 06:37 PM   #1
I have three questions
1. How do you find AC voltage across resistor when there are both AC and DC current?
2. is AC voltage across a resistor different from voltage across a resistor?
3. Find AC voltage across Resistor (in this image)
http://img199.imageshack.us/i/acv.gif/
load line Eq: V(ec)=12-6000*I(c)
answer: 1.08v
2. Relevant equations
Voltage across resistor = I*R
but I do not know if this can be used when there are mixture of
3. The attempt at a solution
well I tried making a AC current by removing battery out of the circuit. I would still get around 3 volts. Also tried using V(max) and V(min) and calculated for I*R(l), but got around 6 volts (which is way off)
now I'm out of ideas. (well I do not understand the problem fully in the first place)
Do I need to use the chart on the bottom?
by the way, does this topic (or anything under circuits, electric fields, and optics-related physics) belong to advanced physics? or is this in the right section?)
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
Oct20-10, 03:57 PM   #2
can I simply find
I(c) max and I(c) min and find both voltage of V(ec) then find the difference divided by 2?
New Reply
Similar discussions for: finding AC voltage across Resistor
Thread Forum Replies
Finding Voltage Across A Resistor in a 1st Order RC Circuit Advanced Physics Homework 1
Voltage across resistor Electrical Engineering 6
voltage across resistor Engineering, Comp Sci, & Technology Homework 1
Voltage Across a resistor Electrical Engineering 8
confused on concept of finding voltage drop across a resistor! Introductory Physics Homework 3
