New Reply
center of mass of semicirculardisk calculated from center of mass of semicircular arc
Share Thread Thread Tools
Oct20-10, 07:40 AM   #1
i have calculated the C.M. of semi-circular arc of radius r and mass m.
How can i use this answer to calculate the C.M of semi-circular disk of radius r and mass m?
ps. how about the converse?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Oct20-10, 10:03 AM   #2
just consider the disk is formed with many semi circular arcs
and for the converse case ,
there are 2 methods
1. consider the CM a semi circular shell, ie. a (disk) - (another disk with smaller radius), then take limit for the radius of the small one approach the bigger one
2. consider the semi circular disk as many triangular laminar......
Oct20-10, 11:06 PM   #3
Quote by sr-candy View Post
there are 2 methods
"just consider the disk is formed with many semi circular arcs" but isn't the arcs different from each other? I thought of this at first but get stuck. How to do this techinically????
"2. consider the semi circular disk as many triangular laminar......"Triangle??confused.Why?and what do you mean by traingular "laminar"????
Oct20-10, 11:42 PM   #4
Quote by jessicaw View Post
1. yes the arcs are of different radius, but you have the CM of the arcs, so you can consider the mass of the arcs are all lying on the y axis, all you have to do is calculate the CM of these "CMs"
2. laminar means layer or plane etc. Just think that a semi circle is formed with many sectors, when the sectors become smaller, it will look like many triangle.
Oct21-10, 02:40 AM   #5
i understand this now, but how can i use this fact to calculate the C.M of arc??? The C.M of triangle is the centroid but the centroid is not on the semicircular arc. So how to use this fact?
Oct21-10, 08:12 AM   #6
Why not? the centroids of these triangles will form an arc
New Reply
Thread Tools
Similar Threads for: center of mass of semicirculardisk calculated from center of mass of semicircular arc
Thread Forum Replies
center of mass and center of gravity different in non uniform gravitation field?expl General Physics 4
the geometric center of the Earth and the center of mass Classical Physics 9
Can two objects with the same center of mass oscillate about that center? Introductory Physics Homework 0
Help with problem of Center of mass, linear mass density and total mass Introductory Physics Homework 1
The center of Mass perfectly match the center of Force-> General Physics 9
