royzizzle
- 50
In this assignment, we will learn how to model flip-flops in the Verilog language and we will use a D flip-flop to construct a simple state machine. Our state machine will act as an “odd parity checker”, a state machine whose output is 1 when it observes an odd number of 1’s at its input since the last reset, and 0 when it has observed an even number of 1’s at its input. The transition equation for such a machine is straight-forward, Q* = Q ^ D, where D is the input being observed, Q is the present state, and Q* is the next state. The output of this state machine is simply Q.
Add a Verilog source file named “parity.v”, and create a module named “parity (clk, reset, d, q)”, with inputs and outputs as in the D flip-flop. Design and enter the description of a circuit that acts as an “odd parity” checker using an instance of the “dff” module from Step 1 (see below).
Verify that the syntax is correct, and compile your Verilog module.
Here is what I have for the dff module and its been tested and works
module dff (clk,reset,d,q);
input clk,reset,d;
output reg q;
always @ (posedge clk or posedge reset) if (reset) q = 0; else q = d;
endmodule
I don't understand how to make the "odd parity module". I'm confused by the definition: does it mean have q output 1 when clk, reset and d combined have a odd number of 1s?
How does the transition equation Q* = Q ^ D fit in with this
HELP!
