Complex Sinusoids Homework: 3.4 x(t) = sin^3(17\pi t)
  • Thread starter Thread starter jordanrs
    Complex Sinusoids
The problem involves the signal x(t) = sin^3(17πt) and requires expressing it in terms of complex exponentials, simplifying it to a sum of sines and cosines, determining its fundamental period, and sketching its spectrum and one period.
  • Participants discuss using Euler's formula to express the sine function in terms of complex exponentials. There is mention of expanding the cubic to find a sum and considering Fourier series decomposition for clarity.
  • Questions arise regarding the calculation of the fundamental period, with some participants suggesting a formula while others challenge its correctness and seek clarification on the relationship between the sine function's argument and the period.
  • There is a discussion about the expected form of the signal and its implications for sketching the spectrum and one period.
The discussion is ongoing, with participants exploring different methods to express the signal and questioning assumptions about the period. Some guidance has been offered regarding the expansion of the cubic and the Fourier series approach, but no consensus has been reached on the correct interpretation or calculations.
Participants are navigating potential misunderstandings about the fundamental period and the implications of using different mathematical approaches. There is also a mention of homework constraints that may affect the discussion.
jordanrs
3.4 Consider the signal [tex]x(t) = sin^3(17\pi t)[/tex]
(a) Express this signal in terms of a sum of complex exponentials.
(b) Simplify this formula to the sum of sines and/or cosines.
(c) What is the fundamental period of x(t)?
(d) Sketch the spectrum for x(t).
(e) Sketch one period of x(t).
D/K
For part (a) i just switched out the sin part for eulers formulad [tex]x(t) = \left (\frac {e^{j17\pi t} - e^{-j17\pi t}}{2j} \right )^3[/tex] but i don't think that's what is meant as its nota summation.
for (b) i imagine its going to use the double angle formulas but could find a succinct way to break up [tex]sin^3(x)[/tex]
for (c) would the fundamental period be would it just be [tex]P = \frac{17\pi}{2\pi}[/tex] making it just [tex]\frac{17}{2}[/tex]
then the final two steps i have no clue
any help would be most appreciated
Welcome to PF!
Well let's test that shall we? Let's say that the period T = 17/2. Then at t = T, I should get the same thing that I get at t = 0:
[tex]\sin(17 \pi \cdot (17/2)) \neq \sin(0)[/tex]
Clearly you are doing something wrong. Hint: the factor that multiplies t in the argument of the sine function is not 2pi * period as you have assumed. However, it is 2pi * (something that is related to the period). What is that something?
You could just expand the cubic -- that would give you your sum. However, I think that what you are probably expected to do here is to compute a Fourier series decomposition of x(t) in order to get the sum. That is consistent with what you are asked in the other parts. In fact, I would do both, since this is a good way to check your answer. Once you've done that, part (b) should follow immediately by simplification of the sum of complex exponentials. You now have a sum of sines and cosines. In other words, the signal has been decomposed into individual frequency components (sinusoids), and these frequencies that compose the signal are harmonically related to each other.
For part (d), the spectrum of the signal is just a plot that indicates the power in different frequency components. In other words, it is a plot of the Fourier series coefficients as a function of omega (I'm giving away the answer to the question in my first post now ;) ).
For part (e) -- seriously?? Just sketch the function over one cycle.
Hello I am new to this forum so please point out any mistakes in general rules I may be over looking.
first sin^3(x) is simple
1/4 (3 sin(x)-sin(3 x))
or (3 Sin[x] - Sin[3 x])/4
or -1/8 i (e^(-i x)-e^(i x))^3
but your equation boils down to : x(t) = 1/4 (3 sin(17 pi t)-sin(51 pi t))
or : x(t) = -1/8 i (e^(-17 i pi t)-e^(17 i pi t))^3
or even: x(t) = sin^3(pi t) (2 cos(2 pi t)+2 cos(4 pi t)+2 cos(6 pi t)+2 cos(8 pi t)+2 cos(10 pi t)+2 cos(12 pi t)+2 cos(14 pi t)+2 cos(16 pi t)+1)^3
I figured the period would be closer to 0.12
the sketch is identical to that of sin^3(x) except compressed to 0-0.12 on the x axis
or maybe i am thinking about this all wrong.
