MozAngeles
- 101
When the Earth, Moon, and Sun form a right triangle, with the Moon located at the right angle, as shown in the figure , the Moon is in its third-quarter phase. (The Earth is viewed here from above its North Pole.)
Find the magnitude of the net force exerted on the Sun.
Find the direction of the net force exerted on the Sun. Give the direction relative to the line connecting the Sun and the Moon.
Gm1m2/R2
Fnet=√F12+F22
[tex]\theta[/tex]= inverse trig (whatever necessary)
Mass sun=1.99E30
Mass earth= 5.98E24
mass moon= 7.35E22
radius sun to moon=1.50E11
radius moon to earth=3.85E8
F1(Sun-Moon)=4.336E20 found by using gravity force eq.
F2(sun earth)= 3.53E22, however this is wrong because it should be 3.58E22, so that means the distance between the sun and the Earth at this time would have to be 1.49E11, which doesn't make since because this should be the hypotenuse, right?. So when using the sencond value for F2, and using hte pythagorean theory I get Fnet=3.57E22, which is the right answer.
NOW to find the direction, i thought you can use the cos inverse *F1/F2, but this turns out to be the wrong answer I have no idea what else to do. Please help!
