Need help solving equations in mechanics class?
  • Context: Undergrad
  • Thread starter Thread starter chubsmalone
    Unknowns
The discussion revolves around solving equations related to mechanics, specifically focusing on a trigonometric equation involving sine and cosine functions. Participants seek assistance with understanding how to manipulate and solve these equations in the context of a mechanics/statics class.
  • Homework-related
  • Josh expresses difficulty in solving a specific equation: -180 = 217.5*cos(theta) + 101.9*sin(theta), and seeks help on how to find theta.
  • Adil suggests that the equation can be transformed to find theta by representing the right-hand side as sin(theta + alpha), where alpha is dependent on the coefficients B and C.
  • Vivek provides a detailed explanation of how to solve equations of the form A*cos(theta) + B*sin(theta) = C, mentioning the use of trigonometric identities and conditions for the existence of solutions.
  • Vivek emphasizes the importance of understanding the oscillatory nature of sine and cosine functions and suggests that the solution can be found using inverse functions.
  • Another participant questions whether both equations need to contain both unknowns for a solution to be valid, indicating a potential misunderstanding of the problem setup.
  • One participant requests clarification on the actual equations and unknowns involved, indicating a need for more specific information to assist effectively.
The discussion reflects a lack of consensus on the specific approach to solving the equation, with various participants offering different methods and insights. Some participants seek clarification on the problem setup, while others provide mathematical techniques without confirming a single solution path.
Participants have not reached a consensus on the best method to solve the equation, and there are varying levels of understanding regarding the application of trigonometric identities and the conditions for solutions.
Students in mechanics or statics classes, individuals interested in trigonometric equations, and those seeking to understand the application of mathematical identities in physics and engineering contexts may find this discussion beneficial.
chubsmalone
I'm in a mechanics\statics class and have run across a couple of problems that I cannot, for the life of me, remember how to solve. The problems end up solving for two unknowns with two equations and one of the equations has
Constant = Constant Sin(theta) + another constant Cos(theta)
and the other equation has sin(theta) and some other unknown.
My statics teacher will help me set up the engineering parts of the problem, but refuses to help me with the math. I should know how to do this, but I can't find it in any of my notes. I appreciate any help anyone can provide for this.
Thanks,
Josh
Mathematics news on Phys.org
Don't both equations have to have both unknowns in them to solve them using a realation?
Could you write out the actual 2 equations u have and the 2 unknowns?
A = B * sin(theta) + C * cos(theta)
you can find the value of `theta' from this equation. the idea is to represent the right-hand side as sin(theta + alpha), where alpha depends on B and C.
-- Adil
Allright,
I was mixed up here when I asked for help. I only have 1 equation, but I still can't solve it. The Eq is -180 = 217.5*cos(theta) + 101.9*sin(theta). I don't know how to solve for theta in this type of equation. I see sadrul's post below, but I'm not sure how to apply it. Thanks again for the help.
--Josh
To know how to solve an equation of the form
[tex]A\cos\theta + B\sin\theta = C[/tex]
you must know two identities in trigonometry, namely
[tex]\sin(A+B) = \sin A\cos B + \cos A\sin B[/tex]
[tex]\cos(A+B) = \cos A\cos B - \sin A\sin B[/tex]
Additionally, you should know that both sine and cosine functions oscillate between -1 and +1. They can of course, assume the values -1 and +1. With a bit of work, you can show that
[tex]A\cos\theta + B\sin\theta = \sqrt{A^2 + B^2}\sin\((\theta + \delta)[/tex]
where [tex]\delta = \sin^{-1}\frac{A}{\sqrt{A^2 + B^2}}[/tex]
Let's leave this an exercise for you so that you are at home with these equations (which will frequently arise in physics, engineering and trigonometry).
From the above description, it should be clear that the equation will have a solution if and only if
[tex]-\sqrt{A^2 + B^2} \leq C \leq +\sqrt{A^2 + B^2}[/tex]
When you rearrange the final equation to solve for theta, you will most likely (except in mathematics where a general solution is required normally) attempt to find the principal value of the argument. That will be easy as you can simply find the inverse function using either a calculator or tables.
Hope that helps...
Cheers
Vivek
