Are Multiple Stereoisomers Produced in Hydroxylation Reactions of Alkenes?
  • Thread starter Thread starter maverick280857
The discussion revolves around the hydroxylation reactions of alkenes, specifically focusing on the stereochemical outcomes when cis and trans-1-phenyl-but-1-ene are treated with osmium tetroxide and aqueous sodium bisulfite. Participants explore the formation of stereoisomers and the nature of the products generated in these reactions.
  • Vivek questions whether multiple stereoisomers are produced in the hydroxylation of cis-1-phenyl-but-1-ene, suggesting that the creation of a stereogenic center should lead to all configurations being formed.
  • Another participant agrees with Vivek's reasoning, indicating that the osmium can attack from different faces of the alkene, leading to enantiomers.
  • chem_tr expresses uncertainty about the second reaction, arguing that osmium tetroxide typically produces syn-diol products and questions the formation of chiral compounds unless the olefin is terminal.
  • chem_tr references a figure from a textbook to support their argument regarding the stereochemistry of the products.
  • A later reply discusses the limitations of the "syn" terminology in straight-chain cases and suggests that the initial osmate ester has both oxygens on the same side, but the final product can adopt different conformations.
Participants express differing views on the stereochemical outcomes of the reactions, particularly regarding the second reaction. While some agree on the potential for multiple stereoisomers, others challenge this notion based on the nature of the products formed with osmium tetroxide.
There are unresolved questions regarding the stereochemical implications of the reactions, particularly the role of syn addition and the behavior of the osmate ester. The discussion highlights the complexity of stereochemical outcomes in these reactions.
maverick280857
Hi
I need some help with the following reactions:
1. cis-1-phenyl-but-1-ene + osmium textroxide + aq sodium bisulfite
2. trans-1-phenyl-but-1-ene + osmium tetroxide + aq sodium bisulfite
To make things simpler, I am attaching a diagram which includes my solution. Reaction 2 is clear to me but I think another product should be formed in the first reaction according to the principle that if a stereogenic center is created in a reaction, all configurations about it are formed. Is this reasoning correct?
Thanks for your help.
Cheers
Vivek
Chemistry news on Phys.org
Yes, your reasoning is correct. The product that you have drawn would come from the osmium attacking the top face of the alkene as you have it drawn. The enantiomer of the product you have drawn could be formed by the osmium attacking the bottom face of the cis compound you have drawn.
Dear friends,
I am not sure about reaction two, as osmium tetroxide (in the presence of an oxidizing agent such as sodium bisulfite) always produces syn- type of compounds, I mean, trans-alkenes with bulky groups will even give syn- diols; so there will not be any chiral compound except that the olefin is located at the terminal. In that case, a vicinal diol is produced with one chiral carbon.
Please view my figure in the attachment, taken from Francis Carey's Organic Chemistry, 1987, ISBN: 0-07-009831-X, from pages 570 and 571.
By the way, your reasoning is true about stereogenic centers, Vivek. Movies is right also, about attacking topwards and bottomwards through an alkene; however, I'm not sure if it is valid for osmium tetroxide as it forms a complex compound.
Regards,
chem_tr
The "syn" terminology tends to fail in straight chain cases because it is dependent on how the compound is drawn. Maverick's picture shows the products in Newman projections, where the horizontal groups are, by convention, protruding out of the plane of the page. I think that if you inspect the image again carefully with this in mind you will find that the image is of the correct racemic product from the trans olefin. Indeed the transition state is as you described, chem_tr, and the initial osmate ester does exist with both oxygens on the same side of the olefin. However, once the osmate ester is cleaved the C-C bond between the hydroxyls can rotate freely and attain a conformation like Maverick drew.
Thanks again chem_tr and movies for all your help.
Cheers
Vivek
11K
34K
