Register to reply
Direction of friction when rolling without slipping
by Referos
Tags: friction, rolling, slipping
Share this thread:
Referos
#1
Oct26-10, 12:50 PM
P: 12
We've just studied rolling without slipping and I was having some trouble deciding the direction of the frictional force in some cases. So I pondered a little bit and recalled how you choose the direction of friction for "normal" translation without rotation:
  • If the friction is static, then its direction is opposed to the tendency of movement (direction of the resultant of the forces parallel to the surface). So if the body has a tendency to move toward the right (there's a resultant to the right), then the static friction will be directed to the left.
  • If the friction is kinetic, then its direction is opposed to the direction of motion parallel to the surface. So if the body is moving to the right, the kinetic friction is to the left.
Hope I didn't forget anything. Anyway, when rolling without slipping, the friction is static, so I presumed this static friction should have the same rules for deciding its direction than static friction in "normal" translation. And this worked! When I solved some exercises with this method, I got the right answer.
This even explains that weird fact that when rolling downhill, friction is uphill, but when rolling uphill, friction is also uphill. This is because whether the body is rolling uphill or downhill, the only resultant force parallel to the surface is Mgsin([tex]\theta[/tex]), [tex]\theta[/tex] the angle of the incline, and this is always directed downhill, so the opposing static friction would always be uphill. Problem solved, right?
Then, my professor gives us a test with a question about a yo-yo that rolls without slipping, which is having its string pulled by someone. The question came with the following free-body diagram:
Which doesn't make sense! The tension force exerted by the string is to the left; the friction should be to the right! Argh!
So HOW exactly do you predict the direction of friction when rolling without slipping?
Thanks.
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
inflector
#2
Oct26-10, 01:11 PM
inflector's Avatar
P: 337
Quote Quote by Referos View Post
Thanks.
Look at the friction arrow from this perspective. If the yoyo was setting on a greased non-stick surface and the yoyo had a lot of mass. What would the string cause the yoyo to do?
Let's say it isn't a yoyo but a bicycle wheel suspended in the air instead? Now as the string on the top of the bicycle wheel is being pulled what does the bottom of the wheel want to do?
So in what direction would friction act if it tended to stop this action on the part of the bottom of the yoyo?
rcgldr
#3
Oct26-10, 02:49 PM
HW Helper
P: 7,131
So how exactly do you predict the direction of friction when rolling without slipping?
The friction is in the direction that corresponds to angular acceleration or deceleration, absent any other sources of torque. In the case of an angled ramp, it's always uphill, because the angular inertia results in the friction opposing the downhill linear acceleration due to gravity.
The diagram depicts a pulley like object with the string attached to the perimeter, not a yo-yo where the string is attached to a small diameter axis within the yo-yo.
Note for a hollow cylinder, the friction force would be zero. I assume the diagram is of a solid uniform cylinder.
In the diagram, the string is generating a torque in addition to the surface the pulley rolls on, and it turns out that the torques are opposing, so the friction force is in the same direction as the string, but smaller.
Comparing the rolling case to a frictionless surface case, in the rolling case, the solid cylinder will have more linear acceleration and less angular acceleration, since friction force is in the same direction as string tension.
It might be easier to visualize this by inverting the situation and observing the speed of the upper surface of an object rolling and accelerating on an accelerating treadmill (the treadmill would be the string). The upper surface of the object moves backwards with respect to the ground, (except for a hollow cylinder where the upper surface doesn't move). Now imagine placing a board on top of the rolling object with it's backwards moving upper surface. It's rate of linear acceleration will increase, and it's rate of angular acceleration will decrease. That board is the equivalent of the friction surface on the bottom of the diagram above, and it's friction force would be in the same direction at the treadmill (string).
Here is an example with real numbers, assume 1 newton of tension in the string, and a 1 kg uniform solid cylinder.
frictionless case (+1 newton string tension, 0 friction force)
cylinder linear acceleration = 1 m / s2
cylinder anglar acceleration / radians = (1 N r) / (1/2 kg r2) = (2 m) / (r s2)
cylinder angular surface acceleration relative to cylinder = 2 m / s2
cylinder bottom surface accleration relative to plane = -1 m / s2
string acceleration relative to plane = 3 m / s2
rolling case (+1 netwon string tension, f = friction force in newtons)
cylinder linear acceleration = (1 + f) m / s2
based on rolling, cylinder angular acceleration / radians = (1 + f) m / (r s2)
based on torques, cylinder angular acceleration / radians = ((1 - f) N r) / (1/2 kg r2) = 2 (1 - f) m / (r s2)
(1 + f) m / (r s2) = 2 (1 - f) m / (r s2)
1 + f = 2 - 2f
3 f = 1
f = 1/3
cylinder linear acceleration = 4/3 m / s2
cylinder angular acceleration / radians = 4/3 m / (r s2)
cylinder angular surface acceleration relative to cylinder = 4/3 m / s2
cylinder bottom surface accleration relative to plane = 0 m / s2
string acceleration relative to plane = 8/3 m / s2
The inclined plane case math for cylinders and spheres was done here:
http://www.physicsforums.com/showthread.php?t=328621
Referos
#4
Oct28-10, 06:20 PM
P: 12
Hmm, from what you guys said, I tried to approach the problem from a different angle...can some somebody check my work please?
I tried using LaTeX, but there's some weird error where I'm only getting thetas no matter what I type, so sorry for readability.
There's a frictional force f = f i on the cylinder (yeah, the exercise said to treat the yo-yo as a cylinder). I don't know the direction of this force; it will depend on the sign of f. The displacement vector of f with respect to the center of mass is rf = -R j, R the radius of the cylinder. Thus the torque caused by the frictional force is tf = -Rf (j x i) = Rf k.
There's also the tension force T = T i due to the string. I'm going to say that this force is being applied from a distance of d*R from the center of mass, d between 0 and 1. If d = 0, the string is being pulled from the center of mass; if d = 1/2, halfway between the CM and the top of the cylinder; if d = 1, from the top, etc (it's a magical intangible string ). So the displacement vector is rT = dR j. The torque is tT = dRT (j x i) = -dRT k.
The resultant torque is t = (Rf - dRT) k. Because t = Iɑ and I = (1/2)MR2, we get (Rf - dRT) k = (1/2)MR2ɑ k (first equation).
The resultant force is F = (T + f)i and from F = MA, we get our second equation: (T + f)i = MA i.
Finally, the tangential acceleration due to circular motion at the point of contact is ɑ x rf = -Rɑ (k x j) = Rɑ i. For rolling without slipping, the acceleration of the CM must be opposite to the tangential acceleration, so A i = -Rɑ i (third equation).
We have three unknowns, f, A and ɑ, and three equations. After playing with algebra, I got:
f = (T/3)(d - 1/2)
This means that if d = 1 (force on top), friction has the same direction as the tension; if d= 0 (force on center), friction is opposite to the tension; and if d = 1/2, there's no friction, so you could roll the cylinder on ice in this case.
The fact that the direction of the frictional force changes based on how you apply the force is really weird, but I suppose it solves the problem, right?
rcgldr
#5
Oct29-10, 01:51 AM
HW Helper
P: 7,131
f = (T/3)(d - 1/2)
This makes sense. If the tention is applied at 1/2 r, the torque is only 1/2 that of the torque applied at r. Since the angular inertia of a solid uniform cylinder is 1/2 m r2, applying the tension at 1/2 r results in zero force. For a hollow cylinder, the angular inertia is 1 m r2, and f = 0 when tension is applied at 1 r. You could repeat the math for a hollow and solid sphere or other objects:
http://en.wikipedia.org/wiki/List_of_moments_of_inertia
Still getting back to the original post, had that diagram shown a hollow cylinder, the friction force would be zero. It's not intuitive that the angular inertia and torque factors, translated into their linear equivalent, end up being relatively less than the linear inertia results in the friction force being in the same direction at the string (if the force is applied at r).
Register to reply
Related Discussions
Direction of static friction while rolling Introductory Physics Homework 13
Direction of Rolling/Sliding Friction Introductory Physics Homework 5
Minimum Angular Speed to start SLIPPING BEFORE ROLLING WITHOUT SLIPPING Introductory Physics Homework 1
Rolling without slipping Introductory Physics Homework 7
