Little help with practice problem for exam
  • Thread starter Thread starter tibu
    Exam
The problem involves a steel ball suspended from two strings, with one string at an angle from the vertical and the other horizontal. The objective is to determine the tension in the lower string, which requires an understanding of force components and equilibrium.
  • Participants discuss the need to separate forces into vertical and horizontal components, with some suggesting that the vertical component of the upper string's tension must balance the weight of the ball. Others question the relationship between the components and the tension in the lower string.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the relationship between the components of tension and the weight of the ball, but there is no consensus on the correct approach as one participant expresses confusion about their calculations.
Participants note that the problem involves assumptions about the angles and the balance of forces, and there is mention of a homework help section on the forum that could provide additional context.
tibu
Hello, I'm new here. Basically I have this practice exercise for my exam.:
A steel ball of mass 4.30 kg is suspended from two strings as shown in the picture. The upper string is at an angle of theta = 27.0° from the vertical, while the lower string is horizontal. Calculate the magnitude of T2, the tension in the lower string.
http://capa.hep.uprm.edu/msuphysicslib/Graphics/Gtype06/prob09_xph183f6pic2.gif
My general problem is that I'm bad with separating forces into components, and I assume this exercise deals with that. Can someone please point me in the right direction to solving this problem? Any help will be greatly appreciated.
okay well, the vertical component of the top string would be equal to weight... baseically 4.3 kg*g(acceleration of gravity). that would be tension*sin27... find out tension, the horizontal components of the two strings cancel out... and the horizontal component of the top string would be tension*cos27
ah, by the way, there is a homework help section on the forum, scroll down to the lower section of the webpage and you should see it
Since gravity is vertical and the string on the right is horizontal you already know the horizontal and vertical components of the other string! :-)
hmm apparently I'm doing something wrong because I don't get the correct answer.
In order to get the tension in the lower string i have to find out the horizontal component of the top string correct?
*Edit*
I'm posting this in the homework help section. Sorry for not noticing this.
  • · Replies 24 ·
9K
  • · Replies 26 ·
14K
