What is the true nature of time?
  • Thread starter Thread starter Parbat
    Mean Time
The discussion centers on the nature of time, exploring its definition, its status as a dimension, and its relationship to space and events. Participants engage with conceptual, theoretical, and philosophical aspects of time, including its implications in physics and relativity.
  • Some participants question the meaning of "time" and express uncertainty about its definition.
  • One participant cites Richard Feynman's perspective that time is what happens when nothing else is happening, suggesting a subjective understanding of time.
  • There is a discussion about whether time can be considered a dimension, with some participants arguing that dimensions are necessary to explain objects, while others challenge this notion.
  • Participants explore the relationship between dimensions, coordinates, and vectors, noting that dimensions are static while vectors are dynamic.
  • One participant raises the idea that time is a one-dimensional quantity used to sequence events, but questions how this aligns with the qualitative attributes of directionality and orthogonality.
  • Another participant suggests that time dilation's relationship with gravity could imply that time might be thought of as a force or energy, although they acknowledge the terminology may not be precise.
  • There is a discussion about the implications of coordinate systems in analyzing events, with some participants asserting that the choice of coordinate system should not affect the analysis.
Participants do not reach a consensus on the nature of time or its classification as a dimension. Multiple competing views remain, with ongoing debate about the definitions and implications of time in physics.
Participants express various assumptions about the definitions of dimensions, coordinates, and how they relate to time. There are unresolved questions about the implications of time dilation and the consistency required in scientific terminology.
Parbat
What does "time" really mean?
i really don't know that.
According to Richard Feynman, Time is what happens when nothing else is happening.
Actually, no one knows how to define time but we all know what it means. So that means you must know what it means. Why do you want to say that you really don't know what time is? You must be referring to some subtle aspect of it, like how can it be going slower for someone moving at a high speed? Is that what you are concerned about?
i mean,how can we say "time" is a dimension?
& dimension means something that is required to explain any object,is that true?
Thanks for asking this question Parbat!
How can time be a dimension? What I was taught in physics:
A dimension is "the least number of COORDINATES required to specify, uniquely, a point in a space."
So is a dimension the same as a coordinate?:confused: I thought dimensions were related to ARCHITECTURE, STRUCTURE and ORIENTATION (shape, geometry) and coordinates were used to specify the LOCATION of things.
In 3D space, the dimensions are LENGTH, WIDTH and HEIGHT, pointing outwards from the object. The coordinates are LONGITUDE, LATITUDE and ALTITUDE and they point inwards, towards the object because the specify location. The corresponding VECTORS would be DEPTH, BREADTH and ELEVATION which specify the mutually orthogonal DIRECTIONS the object moves. Dimensions and coordinates are static while vectors are dynamic. The only attributes common to these three concepts are direction and orthogonality which are QUALITATIVE attributes. That's it.
So how does time fit into this? How is time considered a dimension when it's routinely used--by mathematicians, as a NUMBER LINE--to QUANTIFY?
Time is a one-dimensional quantity used to sequence events, to quantify the durations of events and the intervals between them, and (used together with space) to quantify and measure the motions of objects.
http://en.wikipedia.org/wiki/Time
So if time is a QUANTIFIER of a sequence of events, where/how does the QUALITATIVE attribute of directionality orthogonality come in here? :confused: Or is this merely an attribute that mathematicians (or Einstein) added to create a model/manifold for doing the math? (Minkowski Space-time?):confused:
I don't get it. In science, don't we have to be objective and consistent with the terms (verbs, nouns, adverbs, adjectives) we use as per their definitions? Is't this required to maintain coherence and eliminate the ambiguity often encountered when metaphors are used? Isn't this what distinguishes science from other subjective forms of inquiry (like religion)?
I appologize for the lengthiness/dimension of this post. :-p
I don't understand what it would mean to explain an object.
In relativity, we have four coordinates that are used in order to specify an event. It doesn't make sense in relativity to treat a time coordinate differently from a spatial coordinate, because when one observer is in motion relative to another observer, each observer's measurements of time and distance are related to the other observer's measurements by equations that don't break apart cleanly into time and space equations.
Everything you have said is excellent, but you stopped too soon. You should also have said that your choice of co-ordinate system should not make any difference in how you analyze a situation, don't you agree?
Well, that's the problem. When we try to define the distance between to events, widely separated in distance and time, we will get different answers for every co-ordinate system we use and that's no fun.
So to solve this problem we use a new kind of vector that includes both the normal three-component vector for space and the normal scalar for time, and we call it a four-vector. Then we invent (or discover) a way to calculate a new "distance" called "interval" that is always the same, no matter which co-ordinate system we use to describe, characterize, or analyze any situation.
Does that make sense to you?
I'm not much keen on time as a dimension either. As time dilation is now being proved reactive to gravity, could time be thought of as a force? Perhaps "force" is the wrong termanology but "energy" doesn't quite cut it.
ghwellsjr said:
Everything you have said is excellent, but you stopped to soon. You should also have said that your choice of co-ordinate system should not make any difference in how you analyze a situation, don't you agree?
What do you mean by "analyze a situation"? I'm going to assume that you mean how you describe an event occurring between (at least) two objects?
To analyze = qualify and quantify.
The coordinate system specifies the locations of the objects.
The dimension system specifies the shapes of the objects.
The vector system specifies the motion of the objects.
Coordinates and dimensions and vectors are all concepts used to qualify the situation. At this point, yes, it should make no difference how you analyze the situation if you stay consistent with these systems.
However...in order to quantify the situation we invented another abstract concept called numbers. Specifically number lines. And herein lies the mysterious merger of quantifying and qualifying concepts--numbers (quantifier) and lines (geometric qualifier) respectively. At which point numbers (with magnitude) have now inherited directionality. Vectors inherit magnitude, time inherits directionality.
Why? If you don't muddle qualifiers and quantifiers there shouldn't be a problem. You should be able to objectively qualitatively define the distance between 2 objects in space by the relationship between their coordinates AND further define that distance relationship using a quantifying concept. My issue is in the packaging. When you start assigning attributes like directionality to abstract concepts like time. It's like talking about the direction of love, anger, or the color blue. these are all concepts which only have meaning in the context of the relationship between at least two objects. Eg., anger vs sadness, love vs hate, red vs blue, etc
This is not a trivial issue of semantics. When we use words in science, we must use them consistently as an objective criterion.
No. Sound like convenient mathematical magic to me. :frown: "Abra-kadabra!"... now a scalar is a vector!
Not saying it's useless, it just makes no real life physical sense.
another thing. LENGTH and DISTANCE are NOT synonymous. At least not in science.
LENGTH = used to qualify SHAPE of (one) object
DISTANCE = used to qualify the relationship between (two) objects
There's a QUALITATIVE difference.
People often use these terms interchangeably. They talk about the length of time and concepts like 'time dilation'. What does this mean? You can only distort the SHAPE of an OBJECT. So is time an object?
Again, if these are only metaphors then how can this "science" objective? These circular definitions just introduce avenues for all kinds of circular arguments. What good science shouldn't allow.
I could be very much mistaken, but you can distort the shape of a force.
Does this mean time is a force?
Please excuse me if I am way off here. I do get your circular arguments comment, but isn't that how new concepts are born?
I agree with you, there shouldn't be a problem, but unfortunately, Mother Nature doesn't agree with us and, so, we lose. It does make a difference which co-ordinate system we use and there is no way for us to determine which one is the correct one, so that is why we use the four-vector interval.
Time is placed orthogonal to the three components of space in the "imaginary" direction and it works and that is why we do it. If you don't like it you need to come up with another scheme that works but you can't stick to the one you have because it doesn't work.
-Your descriptions are confusing and overly complicated.
Numbers were/are used for expressing magnitudes, and have been for all of human history. Distances were/are expressed informally as magnitudes with a direction, and formally as vectors. There is no difference between coordinates and dimensions, they are both spatial intervals. The length of an object is the difference between the coordinates of the ends of the object.
-Time is a scalar (number/magnitude) and thus has no direction. The time variable was mathematically manipulated for the purpose of treating it as another dimension.
-A vector/tensor/matrix can contain any number of mixed type of values/attributes, as long as the values are manipulated in a consistent manner. Eg. A personal 'vector' (name, height, weight, eye color, etc...), useful in an employee database.
post#9:
-Processes, mechanical, chemical, etc. are mediated by light. Light speed is constant in space and independent of its origin. When objects such as clocks move, the associated processes slow down. The clock slices time into longer intervals, therefore the clock readings are relative for the observer moving with the clock.
-Science can only measure real world processes, create conceptual models that mimic reality, and keep the ones that are successful. The concepts science uses are all ideal metaphors, just as images are not the objects in the image. We experience the world indirectly.
[/QUOTE]
How can you distort a force? A force has no shape and isn't physical object. You can only distort physical objects that have shape. If you're talking about distorting the vector (or tensor) that describes a force then that's a figurative statement. Just like the statement; "spreading love".
I'm not saying the concept of force is useless of meaningless because it's not!
New concepts should be born from scientific methodology so that the language used to describe them is as objective as possible. For example the concept, viscosity. Viscosity describes how forces change the dimensions of a fluid using corresponding vectors. You never hear people talking about "distorting" the viscosity of a fluid. You distort the shape of the fluid by changing the dimensions that describe its state.
This makes more sense to me.
Please explain. I'm confused.
If it works so good why is gravity a problem? Why aren't the SM and GR compatible? Does this have anything to do with the mathematical formulations of these models? Just asking. Thanks.
Actually they are very simple and objective. I never said that numbers were not used to express magnitudes. They are and very useful at that. But, how can you use an informal definition on the one hand and then incorporate it into a formal definition on the other and hope to maintain consistency when trying to describe things objectively? When you rely on circular definitions and assume synonyms doesn't this confuse things? I thought math was about formal objective descriptions? I know science is supposed to be. Just because this is how people have been doing it since history doesn't make it correct.
Distance and length are NOT synonymous. There is a non-trivial,
qualitative difference between length and distance. Length is used to describe the shape of a continuous object. Distance is used to describe the space between 2 indivisible objects. Look up the definition of distance in any standard English dictionary and that's the definition you'll get; the space between two things.
Do you agree that an object is made up of discrete atoms/particles separated by (a very very considerable amount of) space? I think most of the physics community does. If so, then which coordinates of what particle are you measuring from to determine the length of the object?:confused:
I disagree. Coordinates describe location/position. Dimensions describe shape/structure. Above you said that length is the difference between coordinates of the ends. If you're now saying coordinates = dimensions then you're saying length is the difference between the dimensions of the ends. :confused: This makes absolutely NO sense. How is a dimension a "spatial interval"?
See what I mean.
Could I well it magic then? Because this mathematical manipulation has created a physical thing from concept. A number changes to an object. Only objects have direction. I'm not being facetious.
Fair enough. How consistently and objectively do you think your so-called personality vector can be applied? I have strong doubts that it can. But I have a few computer science buddies working on AI that would be earger to know.:cool:
:confused: The clock slices time? Since you can only slice through a continuous object, then are you suggesting that time is a continuous? But yoou say time is a dimension and you said above that dimensions are spatial intervals. :confused: So are you slicing through the intervals? I'm confused.
Fair enough. I have no issue with metaphors. We can't avoid them as they're pervasive in everyday life. It's the consistency and potential for ambiguity and circular arguments that I have issue with. And by what criteria do you measure success?
I'll leave it here because I don't think this is the appropriate forum for the direction this might be heading.
There are space-like dimensions and time-like dimensions. They are not the same, but they are all part of our 4-dimensional spacetime.
In special and general relativity time for an observer is simply the length between two events that cross his worldline, this length is physically measured by a clock. O more generally it is the calculated length between two events with a timelike distance between them over an arbitrary path
-The reference to informal use is to emphasize that a rigid definition is not needed for practical applications. Travel directions can be very general, eg., 10 miles down route 7 just past Wal-Mart. Scientific study obviously requires more rigid definitions with minimum ambiguity. My reply to the op's question about the meaning of time... it depends on the context. So it goes with definitions, it depends on the purpose.
Here's part of a paper on knowledge which mentions your concern about circular reasoning.
To form knowledge the mind;
--perceives reality,
--forms concepts to model reality,
--predicts reality from these concepts,
--keeps the concepts as knowledge when prediction matches reality.
--modifies the concepts after more perception
knowledge is a set of concepts used as a reference for understanding
By definition knowledge is always incomplete because all reality is never perceived.
For simplicity, a concept is defined within a context that excludes other concepts.
--Other concepts may not be relevant to the purpose.
--There may be relevant concepts that have not been created.
--An approximate definition may be sufficient for the purpose.
Definition is a relative referencing process.
--A definition is expressed in terms of other definitions.
--This process can be circular or incomplete.
Forming knowledge is a continuous process of refinement.
Knowledge is only as good as its definition.
See what I mean.
Chemistry and quantum theory demonstrate that matter is discrete, 2 yeses.
Coordinates are measured from a common origin (by definition).
Three dimensions are sufficient for simple rectangular solids.
1. Place a ruler with the 'o' mark at one end and read the value 10 where the other end contacts the ruler. The length is 10-0=10.
2. Place the ruler with the '4' mark at one end and read the value 14 where the other end contacts the ruler. The length is 14-4=10.
The only difference is where you designate the origin. You are still measuring space.
If 3 4" widgets are end to end, we have 12" of widgets. If the middle one is removed, there is still 4" of space between the other 2, whether it's occupied or not!
I agree with the general gist of what you've said, except the red highlighted. In science, I think it's even more important to be as objective as possible in practical situations.
For example, how does one consistently communicate the concept of a 'time-line' when people have different definitions of what a line is. Is a line, by one definition, a series of points? Or is it, by another definition, the empty space between 2 points? Or a continuous extended rectangle? Do you see how either one of these definitions has a very significant and non-trivial consequence on the meaning of a 'time-line'?
coordinates specify the location or position of one thing. What you described is simply using a ruler to measure the length of a shape. It has nothing to do with coordinates.
You can't measure space. You measure objects in space. You can only talk about the distance between 2 objects in space. But not the length of space. Length is an attribute reserved for shapes.
And you said: "The length of an object is the difference between the coordinates of the ends of the object." and then... "The only difference is where you designate the origin."
Which is what I'm asking you. What exact point (coordinate position/location) in the solid object you're measuring, are you designating as the origin?
When you measure the length of an object, you're measuring the space between the molecule at one end and the molecule at the other end. Whether there is matter in between them is irrelevant.
Objects 1,2, and 3 are small diameter spheres positioned inline. d= center to center distance.
Measure d1 between objects 1 and 2.
Measure d2 between objects 2 and 3.
S is the sum d1+d2. Isn't S the total distance/space between objects 1 and 3?
Space is what prevents everything being in the same place and time is what prevents everything happening at the same time. :-p
Informally most laypersons think of coordinates as specifying a physical location, but in physics, coordinates specify an event, which specifies a location and a time. For example, you might arrange a meeting for next Monday, 10AM in the conference room, then the event is clearly defined and there is a greater chance of actually meeting than if the place or the time are left out. As has already been said, space and time are both specify intervals between events. When you think really hard about it, spatial distance can be just as mysterious as time. For example, when walking down a road you might gauge the distance by counting fence posts, but what about gauging distance crossing a great void in space where there are no fence posts? One way to do that would be to measure your velocity and then time how long it takes to cross the void, or similarly you might send a radar signal across the void and work out the distance from how long it takes the signal to return. Thought of like this, it is easy to see that time and space are intimately related. Consider a hermit that never leaves his cave. You might think it is easy to specify his physical location without specifying a time, but it turns out that this is not true. His physical location in July is different to his physical location in December because the Earth has moved to the other side of the Sun in that time. His physical location in December 2009 is different to his physical location in December 2010 because the Sun has moved a short way around the Galaxy in that time. It becomes clear that the physical location of our apparently stationary hermit is time dependent. This intimate relationship between time and spatial distance even extends to the simple measurement of a length of an object. Let us say we have an object that in one metre long. If the object is moving relative to us and we measure the physical location of the front of the object at 1PM and the physical location of the back of the object at 2PM and subtract the two measurements, then we might conclude that the object is a mile long. Clearly, to make a sensible measurement of the moving object's length, we have to specify that the spatial coordinates of the ends of the objects are measured at the same time, or allow for the velocity and the time difference of the coordinates to calculate the proper length and so even the simple measurement of the length of a humble object requires we take time into our considerations.
Time has always been a part of Galliean coordinates and making time a coordinate component is not a new invention of Einstein or relativity. Relativity just complicates things by demanding that you also specify who's time measurement is being used to specify an event, because time in relativity is not universal as in Newtonian physics.
OK. I see where the issue is now. It's a question of matter, space, discreteness and coherence. Which might be outside the scope of this forum? I don't know.
But to answer your question, since 1, 2 and 3 are separate objects and not a single coherent object, then no. The distance between 1 and 3 would have to be measured from the surface of 1 to the surface of 3.
good one:smile:
Most laypersons?:confused: I thought an event was a dynamic thing...something that happens over some period of time. An occurrence. So are you saying time is a coordinate? :confused: Someone else said it was a "dimension". Now I'm really confused.
And your analogy is bad. If you leave out the day and time you can still locate the conference room. When the conference (event) takes place is a separate issue which can be determined in relation to another/other object(s), whose location(s) can be described by a different set of coordinates--however you chose to calibrate it.
If there are no fence posts and you're the only one in this void of space how would you measure velocity? Also, if velocity is measured as change in position with time you have to measure the time elapsed as you move somehow don't you? Or are you suggesting that you can measure velocity without measuring /recording time?
And as for the radar thing, don't you need another object for the radar's radio waves to hit off of and return?
This is an interesting point you bring up. But I would have to disagree. What's more fundamental here is motion. Space and motion being the most fundamental concepts. Time is a results from the motion of space (or more popularly, things in space).
So in a sense yes, time is connected to space but only through motion. We perceive time because matter (or more fundamentally, space) moves.
Think about your object that's fully characterized by it's spacetime coordinates. You know it's location and "time". Now let's say the object never ever moves. What meaning does time have then? In fact, the velocity of light and the vibration of crystals (both moving things) are the foundations of time in physics.
It is utterly beyond our power to measure the changes of things by time. Quite the contrary, time is an abstraction at which we arrive by means of the changes (motion) of things.-- Ernst Mach
No! The premise of your argument is false. You don't measure the length of an object by subtracting coordinates. Especially an object in motion! What you've described is simply a measurement of the DISTANCE between two positions; one occupied by the front of a moving object @ 1PM and the other occupied by the back of the moving object at 2PM. Concluding the LENGTH of the object from this DISTANCE is wrong!
Sure. If you chose to measure the length of the object as the difference between two coordinates that specify positions at the ends of the object in some calibrated coordinate space then fine. But this would only make sense in the case of a static object. When you move the object the coordinates of the ends change. If you wana determine the length of the object using the coordinates you'd have to stop the object.
From what I learned in physics, a particle in a 3D coordinate space can be described by a position vector (drawn from the origin/reference to the particle). This give the relative position and direction of the particle. What determines whether the particle is at rest or in motion is the change of the vector with respect to the reference frame. If the reference frame doesn't change over time, then the object is pretty much at rest and you can measure the true length.
Time has always been a part of Galilean coordinates and making time a coordinate component is not a new invention of Einstein or relativity. Relativity just complicates things by demanding that you also specify who's time measurement is being used to specify an event, because time in relativity is not universal as in Newtonian physics.
What exactly do you mean by coordinate component? An Galileo even said motion was more fundamental than time. Heck, motion was his shtick.
Time has 3 basic elements
Past - Present - Future
Both the present and future elements can be altered, the past is always constant
Of course you could argue the Past is not always a constant element because time itself is always moving forward so the past then becomes the present and so on
Godswitch said:
... the past then becomes the present ...
It must be an interesting world you live in then. Or should I say...
.neht ni evil uoy dlrow gnitseretni na eb tsum tI
:wink:
Exactly. That's why theses notions of divided time always fall to the paradox of Zeno.
:wink:
lol
With regards to my likening time to a force and statement concerning a force being shaped. Just a thought process: If electricity can be shaped into light bulbs, the strong force into nuclear whatevers and radiation into xray machines then IF time could be considered to be "force like" then it would explain dilation in the form of a shape as you mentioned.
Time as a dimension works mathematically and was derived as such.
If time dilations could be monitored according to the amount of time lapsed in each moment, could a new system of maths be derived?
In the event that time and gravity are linked, would this new system of maths incorporate gravity?
That doesn't make any sense. Without time, there is no motion. However, the converse is not true. Even if there is no motion, time can still be effecting the object. We can do this by setting a particular object at the center of a particular coordinate system.
Dimension is a convenient way to specify how many numbers (or anything else) are needed to tell an objects location in a particular coordinate system. For example, in an N-Dimensional coordinate system (N being any real number) there are N coordinates needed to have a location. We CAN have some of those coordinates be zero, in which case the "space" that the vector is in is isomorphic to another space. If I have one vector, the "space" it is in, called a vector space, is isomorphic to R^1, because a vector is a straight line.
If I have 2 vectors, v = <1,1,0> and u = <0,1,0>, and I span those vectors on, in this case, because I have 3 coordinates, I have a 3 dimensional coordinate system (R^3), while the SPAN is in fact isomorphic to R^2, although the vector space created by the span is still in R^3.
I hope this helps...
edit: I guess this doesn't even come close to answering the OP's question.
From what I understand, time is simply a passage of events, or a coordinate in our 3+1 dimensional world (3 spatial + 1 time). I think what you might be attempting to ask is what makes time go, or why does the arrow of time always point the same direction (although it might not be the same magnitude). It could have to do with entropy, though my knowledge in this is not as strong. Maybe in a year or so I can help more :P
  • · Replies 16 ·
  • · Replies 71 ·
  • · Replies 20 ·
  • · Replies 54 ·
  • · Replies 16 ·
