| New Reply |
What does "time" really mean? |
Share Thread |
| Nov9-10, 11:16 AM | #52 |
What does "time" really mean?"The term 4-D means that it takes 3 spacial coordinates and 1 temporal coordinate to specify the position of a point or event. "An object is said to have as many dimensions as there are axes required to locate its position in space" Are both definitions above correct? |
| Nov9-10, 11:22 AM | #53 |
Let's take, for example, the first half of the twin paradox. The twins (or two identical clocks) start out at the same age (or set to the same time) at the same location. One of them accelerates away and travels at a high speed for awhile and then decelerates and comes to rest with respect to the first twin (or clock) some distance away. This defines two events: the first is when the traveler starts out and the second is when the traveler stops. When this situation is analyzed from different frames of reference, different answers will be determined for the actual physical distance the traveler traversed and for the actual physical time that it took the traveler to make the trip. Do you agree? If yes, then how do you reconcile the different measurements of distance and time? If no, then please explain why. |
| Nov9-10, 01:19 PM | #54 |
I am just saying that you were not defining dimension abstractly enough but you are rather defining spacial dimension in specific instead. |
| Nov9-10, 02:43 PM | #55 |
| Nov9-10, 03:47 PM | #56 |
| Nov9-10, 04:26 PM | #57 |
Mentor
| Nov10-10, 03:18 AM | #58 |
To try again: <We cannot pick-out any one direction in spacetime and say "this is the time direction". Observers in relative motion will not agree. In this regard space and time are inseparable.> How's that? To be really abstract, the difference is that rotations in space have a real valued parameter of rotation, whereas rotations between space and time have an equivalent imaginary parameter. But this doesn't really tell us what class of objects must have their world lines confined to the interior of the light cone... hmm... |
| Nov10-10, 07:57 AM | #59 |
| Nov10-10, 03:08 PM | #60 |
| Nov10-10, 05:13 PM | #61 |
MMX was the inspiration for Lorentz to explain the null result by saying that the physical dimension of the apparatus was contracted along the direction of the aether wind. Michelson, on the other hand, believed that he could not measure the aether wind because he thought the earth was dragging the aether along with it.
| Nov10-10, 05:27 PM | #62 |
I don't think even the best physicst can explain exactly why time is a dimension. The best explanation I have read in any book written by one is that if they where to point out on a map the exact coordinates where you will meet them you would never be able to meet them there without knowing when they will be there. Then the time coordinate allows your meeting.
| Nov10-10, 06:06 PM | #63 |
Mentor
| Nov24-10, 04:21 AM | #64 |
If i'm standing 20 yards away from a tree (where there's a measuring device) and a muon zips past me at near the speed of light, relativity theory says that the distance between the muon an the tree contracts. Now did the static distance between me and the tree shrink or was it the distance between the muon and the tree? And if the answer is the later, then say there's a rock between me and the tree, did the distance between the rock and tree also shrink? |
| Nov24-10, 06:54 AM | #65 |
It is completely consistent and your assertion |
| Nov24-10, 08:45 AM | #66 |
You can use either rest frame (or any other frame) to analyze the situation and they will all get the same answer, which is even though the half-life of the muon is too small for it to survive traveling "long" distances", from your rest frame, it survives because it's clocks are running slow and from its rest frame, it survives because it doesn't have very far to travel. |
| Nov24-10, 08:52 AM | #67 |
| Nov24-10, 10:36 AM | #68 |
Wow, what a question. Well, we all know that time is the duration it takes actions to happen. Time is the fourth dimension, as Einstein viewed it. People before Einstein, like Newton, viewed time as a definite quantity. They viewed it as a definite measurement that is the same for everybody. Then came Einstein, and said that time is in fact relative, it is not an equivalent quantity for everyone. First, he said that the ultimate speed of the universe is the speed of light (you can't go faster than the speed of light). He also said that time is a relative measurement, it depends on your speed; the closer you travel to the speed of light, the slower time beats. Also, time beats faster if you are away from gravitational pull (that's why our GPS works the way it does. It has to take General Theory of Relativity into consideration).That is our basic understanding of time.Time travel to the future is very possible, you just have to go on fast speeds and you age less than your twin, you are in some sense a traveler to the future, However, we don't really know for time travel to the past, because you can't change your past. There are also some new theories on time such as wormholes, and string theory's tiny curled up extra dimensions... The subject of time is really a huge subject, and physicists are still investigating on time.
| New Reply |
Similar discussions for: What does "time" really mean?
| "Speed of time": temperature tells thermal time/proper time (Smerlak Rovelli) | Beyond the Standard Model | 1 | ||
| Calculating Gravitational Time Dilation in black hole/Future Time Travel | Special & General Relativity | 5 | ||
| [Q] Some confuse involving time dependent schrodinger equation and time uncertainty | Quantum Physics | 5 | ||
| Calculate time constant from the slope of dimensionless temperature vs time graph. | Introductory Physics Homework | 2 | ||
| since time slows down in a strong gravitational field, does time stop in a black hole | Special & General Relativity | 12 | ||
