Power series when to use Frobenius method
The discussion revolves around the conditions under which to use the Frobenius method versus the simple power series method for solving differential equations. Participants explore the differences between these methods, particularly in relation to singular points in the equations.
  • One participant inquires about when to use the Frobenius method compared to the simple power series method, noting that the latter seems faster.
  • Some participants assert that the two methods are equivalent, but others challenge this view by highlighting the significance of singular points.
  • A participant explains that the difference between the methods becomes apparent in the presence of a singularity, where the Frobenius method yields a non-trivial value for s.
  • Another participant asks for clarification on how the xs factor contributes to the Frobenius method's effectiveness over the ordinary power series method.
  • One participant describes the Frobenius method as applicable when expanding around a "regular singular point," emphasizing the nature of the singularity involved.
There is no consensus on whether the two methods are equivalent, as some participants argue they are while others highlight important distinctions related to singularities. The discussion remains unresolved regarding the specific advantages of the Frobenius method.
Participants express uncertainty about the conditions under which each method should be applied, particularly regarding the nature of singular points and their implications for the solutions obtained.
John777
Hi, I'm new to the forum and need some help regarding my calc class. Any help you could provide would be greatly appreciated.
In doing a power series series solution when should I use the frobenius method and when should I use the simple power series method. The simple method seems a little faster, but I know there is a certain type of problem where you must use frobenius.
Frobenius being y=[tex]\Sigma[/tex]AnXn+s
Regular method being y =[tex]\Sigma[/tex]AnXn
These 2 are equivalent
Don't take this the wrong way as I'm just trying to learn, but why do they teach both methods? There is no difference between them?
There is a difference between them, but for differential equations without a singularity at some value of x the difference disappears because you will be forced to conclude s = 0.
When you have a differential equation with a singularity at some value of x, you will find a non-trivial value of s when you do a power series around the singular point.
i.e., if you have a singularity at a point x = c, you would plug in a series
[tex]y = \sum_{n=0}^\infty A_n(x-c)^{n+s}[/tex]
and you would get s = some non-zero number. If there were no singularity at x = c, you would find s = 0.
Can you explain what correction does the xs factor contribute exactly? I don't see why the Frobenius method improves the failing ordinary power series method.
You use "Frobenius" method when the point about which you are exanding (the "[itex]x_0[/itex]" in [itex]\sum a_n(x-x_0)^n[/itex]) is a "regular singular point". That means that the leading coefficient has a singularity there, but not "too bad" a singularity: essentially that is acts like [itex](x- x_0)^{-n}[/itex] for nth order equations but no worse. Every DE text I have seen explains all that.
  • · Replies 24 ·
