| New Reply |
Rear view mirrors |
Share Thread | Thread Tools |
| Oct29-10, 06:27 AM | #1 |
Rear view mirrors
In rearview mirrors (convex mirrors) of vehicles it is stated that " Objects are closer than they appear".
But as we see in the ray diagrams of a convex mirrors, the image formed is closer to the mirror than the object so the image is closer than it actually wouldve have been in the case of a plane mirror, so it should have been that the objects are further away than they appear. Yet the image we see is further away and the objects really are closer than they appear.(I tried it with an actual convex mirror) Can anyone help me what is causing this?? |
| Oct29-10, 07:05 AM | #2 |
Mentor
The image in a convex mirror is actually closer to you, but it is also much smaller than it would normally be, so your brain perceives it as being further away.
| Oct29-10, 11:05 AM | #3 |
So is the dimnished image formed enough to form the illusion of a further image?
| Oct29-10, 12:19 PM | #4 |
Mentor
Rear view mirrors
Yes. Suppose that you have a convex mirror with focal length -0.50 m, and an object with size 1.0 m is a distance 10.0 m from the mirror. Calculate the actual image location and size.
Now suppose you are standing a distance 1.0 m from the mirror (with the object 9.0 m behind you). What is the angular size of the image, as seen by you? How far away from you would it have to be, in order to have the same angular size, if it were 1.0 m high? (This is how far away it appears to be.) |
| Oct29-10, 07:39 PM | #5 |
Surely it's a number of accidents waiting to happen,especialy if you havn't read the small print or interpreted it wrongly. |
| Oct29-10, 09:21 PM | #6 |
Mentor
Why do you say "waiting to happen"? Millions of these mirrors have been in use for several decades already. If, after all that time, we are still waiting for this to someday cause an accident, that only proves it is not a major problem.
If people need to gauge the distance to something accurately, I think they mostly look directly at it or use the central rear-view mirror (which is flat and does not distort the true distance). At least that's what I do. |
| Oct30-10, 05:14 AM | #7 |
It does seem silly though to be forced by some manufacturers to use a sight adjustment device. Imagine if these same producers made it a requirement that everyone had to wear optical glasses to adjust there vision irrespective of the quality of there eyesight,before they were allowed to drive forewards in one of there vehicles. It would be thought as ludicrous. In effect though that is what they are imposing on drivers when they reverse. If a driver can't see properly from a flat mirror he should get himself glasses not the car maker. |
| Oct30-10, 07:54 AM | #8 |
Mentor
| Oct30-10, 11:15 AM | #9 |
Here in the U.K. all three of our vehicles have convex mirrors on the passengers side and drivers side, the rear view mirrors all appear to be flat, except for the Range Rover, which I am not sure if it has a true image or not. I presume you are referring to cars in the U.S.A. which if true when I visit I must remember to stick my neck out of the window and risk a cricked one.
| Oct30-10, 12:11 PM | #10 |
Mentor
| Oct30-10, 01:15 PM | #11 |
If you don't adjust reality to take into account of what you see when you are reversing you will crash. |
| Oct31-10, 09:09 AM | #12 |
Mentor
From my experience, as an actual driver, I can tell you that these mirrors are not a hazard, and the wider field of view they offer is truly a help. |
| Oct31-10, 10:36 AM | #13 |
I suppose you could deduce from that I don't drive and just like to look at them. As for problems when using these mirrors to be honest yes. |
| Oct31-10, 11:27 AM | #14 |
Mentor
| Oct31-10, 11:38 AM | #15 |
Buckley: your assumptions about the purpose of side view mirrors is in error. This is also incidentally causing you be driving improperly.
Side view mirrors are NOT for the purpose of determining the DISTANCE to an object. They are simply there so that the driver can determine IF there is an object there AT ALL. If the mirrors were not convex, the field of view that they displayed of what is behind the driver would be so narrow as to be useless (I've done this, it's useless). There are only two ways to see a large field of view: make much larger mirrors (both impractical AND dangerous), or have small mirrors show a wider field of view. Drivers manuals tell you that you do not TRUST your mirrors to give you the whole picture. It is your reponsibility to LOOK OVER YOUR SHOULDER. |
| Oct31-10, 06:20 PM | #16 |
Mentor
I'm not going to argue about the definition of a term you made up: whatever you call them, they are very much unlike glasses. |
| Oct31-10, 06:57 PM | #17 |
Do you reckon it might be a subtle ploy to force us into a position whereby we don't trust our mirrors and therefore this forces you to look over your shoulder. Unfortunately the less subtle might not have read any manuals and expect to take what they see as expected. |
| New Reply |
| Tags |
| convex mirrors, optics |
| Thread Tools | |
Similar Threads for: Rear view mirrors
| rubber stopper hanging from the view view mirror of a car... | Introductory Physics Homework | 7 | ||
| Why do Parallel Mirrors produce infinite mirrors? | Introductory Physics Homework | 5 | ||
| Mirrors (concave) + questions on lens and mirrors | Introductory Physics Homework | 4 | ||
| Field of view of cylindrical mirrors | Advanced Physics Homework | 5 | ||
| Rear collision momentum | Introductory Physics Homework | 2 | ||
