Calculate Third Force Direction and Magnitude | Forces and Velocity Problem Help
  • Thread starter Thread starter dg_5021
    Force
The problem involves calculating the direction and magnitude of a third force acting on an object moving with constant velocity under the influence of two known forces: 6.5N in the positive x direction and 4.4N in the negative y direction. The magnitude of the third force is determined to be 7.9N using the Pythagorean theorem. The direction is calculated using the arctangent function, where the user incorrectly used radians instead of degrees, leading to a miscalculation of the angle as 0.59507 instead of the correct 34.1 degrees.
  • Understanding of vector addition in physics
  • Familiarity with trigonometric functions, specifically tangent and arctangent
  • Knowledge of force vectors and their components
  • Proficiency in using scientific calculators for angle conversions
  • Review vector addition and equilibrium conditions in physics
  • Learn about the correct use of arctangent for angle calculations
  • Study the conversion between radians and degrees in trigonometry
  • Practice problems involving multiple forces and their resultant vectors
Students studying physics, particularly those focusing on mechanics and force analysis, as well as educators looking for examples of vector problems and their solutions.
dg_5021
Problem-
An Object acted on by three forces moves with constant velocity. One force acting on the object is in the positive x direction and has a magnitude of 6.5N; a second force has a magnitude of 4.4N and points in the negative y direction. Find the direction and magnitude of the third force acting on the object.
answer-
(6.5^2 + 4.4^2)^1/2
=7.9N
Am having problems getting the answer for the direction. I used
Tan^- (4.4/6.5)= but I get .59507
and the answer in the back of the book is 34.1 for the direction. What am I doing wrong?please help
Your calculator is in radians.:)
thanks for the help
  • · Replies 18 ·
  • · Replies 21 ·
