Register to reply
Net work problem with F cos theta
by loganblacke
Tags: theta, work
Share this thread:
loganblacke
#1
Oct29-10, 10:41 AM
P: 48
The graph below shows the component (Fcos(theta)) of the net force that acts on a 5.0 kg block as it moves along a flat horizontal surface. Find (a) the net work done on the block and (b) the final speed of the block if it starts from rest at s = 0.
The graph shows Fcos(theta)(N) as the y-axis and s (meters) as the x-axis. The coordinates are (0,0), (1,0), (1,2), (4,2), (4,-2), (6,-2), (6,0), (8,0), connected by straight lines in that order.
2. Relevant equations
Work=Force*Distance*cos(theta)
3. The attempt at a solution
I don't understand what the y value represents or what values to assign for theta. Please help!
Phys.Org News Partner Science news on Phys.org
Mysterious source of ozone-depleting chemical baffles NASA
Water leads to chemical that gunks up biofuels production
How lizards regenerate their tails: Researchers discover genetic 'recipe'
paragchitnis
#2
Oct29-10, 11:01 AM
P: 25
Work = Force x cos[tex]\Theta[/tex] x distance
This is the area under the given graph between Fcos[tex]\Theta[/tex] and s
paragchitnis
#3
Oct29-10, 11:16 AM
P: 25
Fcos[tex]\Theta[/tex] is the force acting in the direction of the motion of the body.
The acceleration of the body in the direction of motion can be calculated as
Force = mass x acceleration
After finding acceleration use
vf2 = vi2 + 2ax
loganblacke
#4
Oct29-10, 12:36 PM
P: 48
A=.25/5.0=.05 m/s
Vf=sqrt(2*.05*8)=.8944 m/s^2
Thank you for your help!!!
paragchitnis
#5
Oct30-10, 09:51 AM
P: 25
Thank you for giving new problem to me.
Is the answer correct?
Register to reply
Related Discussions
Proving: limit (as theta approaches zero) of sin(theta)/(theta) = 1 Calculus & Beyond Homework 2
Inequality involving theta and sin(theta) Calculus & Beyond Homework 1
Theta problem o_0 Introductory Physics Homework 13
Understanding Cosine Theta in Work Equation Introductory Physics Homework 2
Easy: given theta, uncertainity on cos(theta) Introductory Physics Homework 5
