Register to reply
Vortex Tube Problem / Control Volume Analysis Using 1st & 2nd Laws of Thermodynamics
Share this thread:
Valgorithm
#1
Oct29-10, 03:16 PM
P: 1
Prior to completing an experiment in which the objective was to analyze control volume energy and entropy in a vortex tube in the Thermal and Fluid Science Laboratory course I am taking, I was required to solve the following two thermodynamics problems:
1. A vortex tube has an air inlet flow at 20C, 200 kPa, and two exit flows of 100 kPa, one at 0C and the other at 40C. The tube has no external heat transfer and no work and all the flows are steady and have negligible kinetic energy. Find the fraction of the inlet flow that comes out at 0C. Is this setup possible?
2. A Hilsch (vortex) tube has an air inlet mass flow of 50 SLPM at 20C, 200 kPa, and two exit flows of 100 kPa, one at 0C and the other at 40C. The tube has no external heat transfer and no work and all the flows are at steady state and have negligible kinetic energy. Find the fraction of the inlet flow that comes out at 0C. Is this setup possible?
2. Relevant equations
In order to solve the first problem, I used the first law of thermodynamics (or the conservation of energy principle) in combination with conservation of mass to determine the fraction of the inlet flow exiting at 0C:
To determine if the setup is possible, I then used the following equation to determine the amount of entropy generated within the system (per unit mass), dividing this equation by the inlet mass flow rate in combination with substituting in the previously found fraction of the inlet flow exiting at 0C:
Also note that I assumed constant specific heat for air in determining the enthalpy and entropy changes in the equations above. The relations I used, respectively, resembled the following:
3. The attempt at a solution
Without going through the details of my solution - since I'm fairly certain that I've obtained the correct answers for the first problem - I found the fraction of the inlet flow that comes out at 0C to be 0.5, while the setup proved to be possible, since the entropy generated was 0.1966 kJ/kg K and therefore greater than zero. My real question pertains to the second problem and how the introduction of a numerical value for the inlet volumetric flow rate alters the solution to the first problem. Wouldn't the fraction of the inlet flow exiting at 0C remain the same regardless of whether or not a numerical value for the inlet flow rate is specified? I also have some confusion as to how to handle "standard liters per minute" and the fact that the given inlet conditions are not standard. Would a conversion from standard volumetric flow rate to actual be necessary? It is my understanding that it would be acceptable, if working in ratios of mass flow rates as I've done, to use ratios of standard volumetric flow rates instead, since doing so will yield the same result.
I asked the teacher's assistant whether or not the two problems were asking the same questions. He said they are two different problems and mentioned that the second one involves some sort of analysis of the mass flow rates according to conservation of mass. I can only surmise that perhaps the second problem is asking for the actual numerical value of the mass flow rate exiting at 0C; however, if that's the case, the problem statement is not very clear. Any assistance with or thoughts on how I can handle this second problem are greatly appreciated!
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
Register to reply
Related Discussions
Vortex tube ? Mechanical Engineering 2
Vortex tube design Mechanical Engineering 25
Thermodynamics: Control Volume flow through radiatior Engineering, Comp Sci, & Technology Homework 10
Thermodynamics: Control Volume analysis using energy Engineering, Comp Sci, & Technology Homework 3
Vortex tube: effect of cooling General Physics 1
