Solution to the exact differential equation
The discussion revolves around solving the exact differential equation given by (x^2)(y^3) + x(1 + y^2)y' = 0. Participants explore the method of finding an integrating factor, the integration process, and discrepancies between their solutions and a textbook answer.
  • One participant claims the integrating factor to make the equation exact is (1)/(xy^3) and proposes a solution of c = .5x^2.
  • Another participant questions the correctness of the initial equation and suggests that the solution should include y, pointing out that c = .5x^2 implies x is treated as a constant.
  • A different participant states that the equation is separable and provides their integration method, arriving at the textbook's solution.
  • One participant details their separation of variables approach, leading to the conclusion that c = 2ln(y) - y^-2 + x^2, while noting that the constant can be adjusted.
Participants express disagreement regarding the correctness of the initial solution and the method used. Multiple competing views on the integration process and the resulting solutions remain unresolved.
There are indications of missing assumptions regarding the treatment of constants and the integration process. The discussion reflects varying interpretations of the differential equation's structure.
fresh
the integrating factor to make the above equation exact is (1)/(xy^3)
i have worked this equation out and have c = .5x^2 as the solution; however, the textbook says the solution is c = x^2 - y^(-2) + 2lnlyl
apparently they got this solution because h'(y) = y^(-3) + y(-1)
i found h'(y) to be equal to zero.
some sort of feedback would be greatly appreciated.
I get a positive sign with a factor of 2 for the middle term compared with the textbook solution. Are you sure you typed it correctly?
I just did a direct integration of the ODE since it's separable.
Do you understand that "c= .5x^2" says that x is a constant? What happened to y in your solution?
By the way, this equation is separable. It's easier to do it that way.
This is a seperable equation from the get go. I got the book's answer.
It separates to [(1 + y^2) / y^3 ] dy = -x dx . Once you integrate both sides you get :
ln(y) - 1/2y^2 = -(x^2 / 2) + c. Solve for c gives you :
c = 2ln(y) - y^-2 + x^2 Don't worry about the fact that c would really be 2c, because it is just a constant.
-A
  • · Replies 52 ·
10K
  • · Replies 16 ·
  • · Replies 0 ·
