Calculating Bullet Speed for Pendulum Swing?
The forum discussion centers on calculating the speed of a bullet impacting a wooden block and the subsequent motion of the block. The first problem involves a 20.0 gram bullet and a 2.50 kg block, where the bullet's speed after impact is calculated using conservation of momentum and energy principles. The second problem addresses a bullet passing through a block suspended as a pendulum, requiring the bullet to have a minimum speed to ensure the pendulum completes a 180-degree swing. The correct answer for the bullet's speed in the second problem is derived from a combination of momentum conservation and energy conservation, leading to the conclusion that the minimum speed must be (3/2)Msqrt(5gL)/m.
  • Understanding of conservation of momentum in inelastic collisions
  • Knowledge of kinetic and potential energy principles
  • Familiarity with the coefficient of kinetic friction and its application
  • Basic physics of pendulum motion and circular motion dynamics
  • Study the derivation of conservation of momentum equations in inelastic collisions
  • Learn about the role of kinetic friction in motion analysis
  • Explore the dynamics of pendulum motion, focusing on energy conservation and tension forces
  • Investigate the application of conservation of energy in systems with both kinetic and potential energy
Physics students, educators, and anyone interested in understanding momentum and energy conservation principles in collision and pendulum problems.
miss_story
Conversation of Momentum (2 problems)
The problem:
"A 20.0 gram bullet is fired into a 2.50 kg wooden block initially at rest on a horizontal surface. After impact the block slides 2.50 m before coming to a rest. If the coefficient of kinetic friction between the block and the surface is .600, what was the speed of the bullet immediately after impact? Derive the necessary equations."
Given:
mA = mass of bullet = 20.0 g = .02 kg
mB = mass of block = 2.50 kg
VBi = initial velocity of the block = 0
d = distance block travels after collision = 2.50 m
u = mu or the coefficient of kinetic friction = .600
Vf = final velocity of masses = 0
Conservation of momentum when the collision is inelastic
mAVAi + mBVBi = (mA + mB)V
Conservation of energy in the presence of a non-conservative force
Since this system only has kinetic energy, the formula is:
(1/2)(mA + mB)Vf^2 - (1/2)(mA + mB)V^2 = -Fkd
where Fk is the force of kinetic friction, and Fk = uN and N = the normal force.
Here are links to the work I did:
Pg. 1
http://www.box.net/shared/8n4dx0bq6b
Pg. 2
http://www.box.net/shared/39qk8an8ae
I don't have the calculation in the written work, but this is what I did:
VAi = (.02 + 2.50)(sqrt(2*.60*9.8*2.50))/.02
VAi = 683 m/s
However, the answer that my teacher has the correct answer is 68.3, so my answer is off by a power of 10, but I don't know what I did wrong...I've done the problem twice (and if you look at my solution, it takes me awhile each time heh) and I still can't figure it out. Any help is appreciated!
Problem #2
The problem:
"A bullet of mass m is fired into a wooden block of mass M, suspended from a rod (considered massless) of length L. The bullet passes through the block and comes out with a third of its original speed. What must be the minimum speed of the bullet if the pendulum is to swing 180 degrees, barely remaining on a circular path?"
Given:
Vmf = the velocity of the bullet after collision = (1/3)Vmi
Since the pendulum barely remains along a circular path, the velocity of the block at the top of the circular path, VMtop = 0.
Cons of Momentum:
mVmi + MVMi = mVmf + MVMf
Cons of Energy (this system has potential gravitational energy and kinetic energy), applied after collision to the block:
(1/2)M(VMf)^2 + Mghi = (1/2)M(VMtop)^2 + Mghf
I set up my coordinate system so that y = 0 when the pendulum was at rest initially. So, that means hi = 0, and hf = 2L.
I assumed the initial velocity of the block before collision is zero because I assumed the block was at rest. So, VMi = 0
So, my equations become:
Cons of Momentum:
mVmi = mVmf + MVMf
and mVmf = (1/3)Vmi, so the equation now becomes:
mVmi = (1/3)Vmi + MVMf
(2/3)mVmi = MVMf
Vmi = (3/2)(MVMf)/m
Solving the cons of energy equation for VMf gives VMf = 2sqrt(gL)
Subbing that into the equation from the cons. of momentum gives:
Vmi = 3Msqrt(gL)/m
The answer my teacher has is (3/2)Msqrt(5gL)/m. I have no idea how he got 5gL under the sqrt root.
Though I was too lazy to check your first problem---I think it's a calculation error----you did not correctly find the required velocity for pendulum to make a complete rotation in the second problem. You can not find out this speed by only conserving energy----the correct limiting condition is for tension in the thread and not the velocity of the pendulum to vanish. That gives you sqrt(5gl).
Hint:Try using a little dynamics as well as energy conservation.
  • · Replies 31 ·
