How do I solve this Charles's Law problem using given information?
  • Thread starter Thread starter lj19
    Law
The discussion revolves around solving a problem using Charles's Law, specifically addressing the relationship between volume and temperature of a gas. Participants explore the application of the law, the importance of absolute temperature, and the implications of using Celsius versus Kelvin in calculations.
  • Homework-related
  • One participant presents a problem using Charles's Law and attempts a solution, substituting values into the equation.
  • Several participants clarify that T represents temperature in the equation, but there is confusion about which temperature is being referred to.
  • Some participants assert that absolute temperature must be used for the calculations, implying that the problem cannot be solved correctly without converting Celsius to Kelvin.
  • Others argue that the information from external sources, like Wikipedia, is not applicable to their class context, as they have not been taught about absolute temperature.
  • A participant expresses frustration over the insistence on using absolute temperature, claiming that their previous problems were solved without it.
  • There is a request for clarification on whether 166 Celsius needs to be converted to Kelvin for the calculations.
  • Another participant insists that the calculations must be done using Kelvin, as Charles's Law requires absolute temperature.
Participants disagree on the necessity of using absolute temperature for solving the problem. Some maintain that it is essential, while others believe they can solve it using the given information without conversion.
There is a lack of consensus on the application of Charles's Law in this context, particularly regarding the treatment of temperature units. Some participants express that their educational background does not include the concept of absolute temperature, which complicates the discussion.
lj19
QUESTION WITH GIVEN INFORMATION:
How would I solve this problem using Charles's Law?
V1=169-L. V2=85-L. T2=166c.
The answer is in Celsius.EQUATION:
Charles's Law is: V1/T1=V2/T2.THE ATTEMPT AT A SOLUTION:
This problem is from an online homework source. I substituted the given information into the equation for Charles's Law: 169/x=85/166->85x=28054->x=330.
What is T?
T=temperature. V=volume.
What temperature?
T is the symbol for temperature in equation for Charles's Law.
That's not what I am asking about. This is not "any" temperature. It has a specific name.
Check wikipedia article on Charles' law.
For this class, I am supposed to know that T=temperature. In this problem, T1=unknown, and T2=166 Celsius.
No. Please read wikipedia article. Repeating the same wrong information won't get you to the right answer. There is something important that you are missing about the temperature.
I have read the Wikipedia article on Charles's Law. The information provided on the article cannot be applied in this class for this problem, because I have not been taught absolute temperature, or other information from that article.
I understand how to solve this problem, as I provided under my attempts to solve it, but if I solve it using the equation for Charles's Law, the answer is not correct.
That only means you have been not paying attention during class. It is impossible to solve the question not using absolute temperature.
There are no different laws for different classes - physics laws are universal. They can be formulated in a slightly different way, but they are exactly the same.
Please check what is an absolute temperature scale unit, perhaps that will show you where is your mistake.
This problem was one part of a three part problem. The other two problems were in the same format using Charles's Law, except with different numbers. I have not been taught absolute temperature. The problem can only be solved by using the givens and plugging them into the equation for Charles's Law, and then solving it, which I have done. I did the exact same thing with the other two problems, and they are correct.
Could someone please explain to me if when solving this problem, I need to convert 166 Celsius to Kelvin's to Celsius? The final answer is in Celsius.
You need to use absolute temperature. Absolute temperature is the one measured in Kelvins. So yes, you have to convert to Kelvins first, do the calculations using Kelvins (because Charles' law requires absolute temperature), then convert back to Celsius.
If you were not so stubborn in repeating the same wrong information again and again you would finish solving this question long ago.
