How is a cantilever beam loaded at the end in uniaxial stress?
  • Thread starter Thread starter Altairs
    Confusion Stress
The discussion clarifies that a cantilever beam loaded at the end can experience uniaxial stress, particularly on its top and bottom surfaces. While the beam bends under load, the stress remains uniaxial in the x-direction, with no shear stresses present on these surfaces. The confusion arises from the presence of shear stresses at the clamped end and the loading point, which do not affect the uniaxial nature of the stress on the beam's surfaces. Understanding the definitions of principal stress and uniaxial stress is essential for grasping this concept.
  • Understanding of cantilever beam mechanics
  • Knowledge of stress types: uniaxial, biaxial, triaxial
  • Familiarity with principal stress concepts
  • Basic grasp of shear stress implications in structural analysis
  • Study the mechanics of cantilever beams under various loading conditions
  • Learn about shear stress distribution in beams
  • Explore the concept of principal stresses in detail
  • Investigate the effects of bending moments on beam stress profiles
Structural engineers, mechanical engineers, and students studying mechanics of materials will benefit from this discussion, particularly those focusing on beam analysis and stress evaluation.
Altairs
When the term uniaxial comes I imagine something being pulled or pushed in one direction only. Confusion is that I read online http://enpub.fulton.asu.edu/imtl/HTML/Manuals/MC105_Cantilever_Flexure.htm" that a cantilever beam loaded at the end is also in uniaxial stress. This is what I can not understand. How? The point at the end where it is being loaded is free and the cantilever will bend so how can it be in uniaxial stress ?
Please explain (not in terms of principal stresses as it is even more confusing :-( )
thx.
Hi Altairs,
thx.
Not in terms of principal stress? hmmm... that makes it a bit more difficult. I think you'll need to understand what a principal stress is, but for the example under consideration (cantilevered beam) it might be easier to ignore that for a moment.
For the beam, let's consider the typical x,y,z directions (x is left/right, y is up/down, z is into/out of the plane).
The statement is:
Another characteristic of the cantilever beam used in this experiment is that the stress is uniaxial everywhere on the [top and bottom] beam surface except in the immediate vicinity of the loading point and the clamped end.
I added the "top and bottom" because that's what they mean when they talk about the beam surface. They're not talking about the side surfaces which are subject to both normal stresses in the x direction plus shear stresses. These other locations result in stresses in more than 1 direction (not uniaxial). But for the top and bottom surface of the beam, there are no shear stresses (on an infintesimal element). The stresses on the top and bottom are all in the x direction. There are no stresses in the y or z direction and there are no shear stresses on the surface. Note however that there are shear stresses where the beam meets the wall which is mentioned in the statement on that link you gave.
I think that might also help define what a http://vacaero.com/Glossary-P.html" is:
Principal stress (normal)
The maximum or minimum value of the normal stress at a point in a plane considered with respect to all possible orientations of the considered plane. On such principal planes the shear stress is zero. There are three principal stresses on three mutually perpendicular planes. The state of stress at a point may be (1) uniaxial, a state of stress in which two of the three principal stresses are zero, (2) biaxial, a state of stress in which only one of the three principal stresses is zero, and (3) triaxial, a state of stress in which none of the principal stresses is zero. Multiaxial stress refers to either biaxial or triaxial stress.
Then the http://vacaero.com/Glossary-U.html" can be defined as:
Uniaxial stress
A state of stress in which two of the three principal stresses are zero.
Q_Goest said:
Hi Altairs,
The statement is:
Got it.
Thx a lot. *thumbs up*
  • · Replies 30 ·
10K
