Why Does Refraction Cause an Elliptical Sun?
  • Context: High School
  • Thread starter Thread starter Pranav Jha
    Cause Refraction Sun
The elliptical appearance of the Sun during sunset and sunrise is primarily due to atmospheric refraction. As sunlight passes through the Earth's atmosphere, the rays from the lower edge of the Sun are bent more than those from the upper edge, resulting in a shortened vertical diameter. This phenomenon is explained by Snell's Law, which states that light rays meeting a surface at a greater angle from the perpendicular are refracted more. The effect diminishes with increased elevation, as rays from the top of the Sun travel through less atmosphere than those from the bottom.
  • Understanding of Snell's Law
  • Basic knowledge of atmospheric refraction
  • Familiarity with the concept of light propagation
  • Awareness of the Earth's atmospheric layers
  • Research Snell's Law and its applications in optics
  • Explore the principles of atmospheric refraction in detail
  • Study the effects of elevation on light behavior
  • Investigate other optical phenomena caused by atmospheric conditions
Students of physics, educators explaining optical phenomena, and anyone interested in the science behind atmospheric effects on celestial bodies.
Pranav Jha
Why does sun appear elliptical during sunset and sunrise?
I have read that when the Sun (or Moon) is near the horizon, the rays from the lower edge are bent more than the rays from the upper edge. This produces a shortening of the vertical diameter, causing the Sun to appear elliptical
BUT i don't understand why the rays from lower edge are more bent due to refraction.
Science news on Phys.org
There is a lensing effect of atmosphere that makes this effect really noticeable, but even if you forget that, just think of atmosphere as a layer of glass. When you watch Sun near horizon, the light from top edge hits Earth near the place where you are standing more straight on than light from bottom edge. And by laws of refraction, the light that meets surface at greater angle from perpendicular is refracted more. Look up Snell's Law.
The effect falls off sharply with increased elevation. The rays from the top of the Sun are going through less atmosphere than are the rays from the bottom of the Sun.
  • · Replies 27 ·
10K
  • · Replies 23 ·
