Probability Question.Can somone tell me if i am doing right thing
  • Thread starter Thread starter cloud360
    Probability
The discussion revolves around a probability problem involving the formation of a committee from a group of scientists, specifically focusing on the voting behavior of the committee members based on their professional backgrounds. The original poster presents a series of questions regarding the probability of the committee voting in favor of a proposal under different scenarios.
  • The original poster attempts to calculate probabilities based on different configurations of committee members, questioning whether their methods and results are correct. Participants raise skepticism about the calculations and suggest the need for reevaluation of certain combinatorial approaches.
Participants are actively engaging with the original poster's calculations, providing feedback and raising questions about specific steps taken. Some guidance has been offered regarding potential errors in the calculations, and the original poster is encouraged to reflect on their reasoning process.
There are indications of confusion regarding combinatorial counting and the application of the addition rule in probability. The original poster expresses urgency due to an upcoming exam, highlighting the pressure to understand the mistakes made in their calculations.
cloud360
I WANNA KNOW IF MY ANSWERS AND METHOD ARE CORRECT
A science committee of 3 people is to be formed from a group of 17 scientists (7 biologists, 4
physicists and 6 chemists) with each possible committee equally likely.
What is the probability the committee vote in favour of a proposal given:-
(a) all biologists in favour, everybody else against?
(b) all chemists against, everybody else in favour?
(c) all biologists in favour, all chemists against and all physicists abstain?
none
Favour =Majority of comitte favour i.e at least 2 of 3 favour
For question 1
Sample space = (17C3)=680
If biologist all favour.. Then for favour, 2 biologist or 3 biologist in the comitee
Event 1= 2 biologist and 1 other=(7C2)*(10C1) =210
Event 2= 3 biologist and 0 other=(7C2)*(10C0) =35
245/Sample space = 245/680 = 49/136=36%
IS THIS CORRECT?
For question 2
If bioligist all favour + phyicists all favour + all chemist against. Then we have many events. So is better to use addition rule.
Addition rule = E + NOT E=Sample Space.....where E= favour
NOT E= 2 chemists or 3 chemists in comitee
Event 1= 2 chemist and 1 other=(6C2)*(10C1) =150
Event 2= 3 chemist and 0 other=(6C2)*(10C0) =15
NOT E=150+15=165
(Sample space-NOT E) = E=680-165=515
515/Sample Space=Probability of E=515/680=103/136=75.7%
IS THIS CORRECT METHOD?
For question 3
If all biologist favour + all chemist against + all physicists don't give a damn.
Favour = (3 biologist)+(2 biologist+1 Other) =Question 1
Favour = (1 bioligist + 2 physicists) +(2 bioligist + 1 physicists)
Favour = (2 bioligist + 1 chemist)
NOT favour=(1 chemist + 2 physicist) + (2 chemist + 1 physicist) + (3 chemist)
NOT favour=(2 chemist + bioligist)
NOT favour=(6C1)(4C2) + (6C2)(4C1) +(6C3) + (6C2)(7C1)=36+60+20+105=221
Sample space - NOT favour = 680-221=459
459/680=27/40=67.5%
IS THIS CORRECT METHOD AND ANSWER?
For question 1: I like your 245/680.
For question 2: I'm very skeptical about your 515/680 and think that is a little too high and you should check that again.
For question 3: I'm very skeptical about your 459/680 and think that is much too high and you should check that again.
Thanks for your time. I really appreciate it.
Question 1 has 7 people in favour
Question 2 has 11 people in favour (so should be higher than Q1)
Question 3 has 7 people in favour but this time can pass with 1 biologist, given 2 physicists.
Can you tell me what i did in my working out, that made you skeptical.
I expected my initial hints would be enough. Try again.
For Question 2 I believe neither your (6C2)*(10C1) nor your (6C2)*(10C0) are correct. Why?
For Question 3 I believe your population-opposed is missing something essential. What?
Now, if I am correct, the more important thing for you to discover is why you made this kind of mistakes and why you were not able to discover them and what changes you could make to try to make to avoid this in the future. That will be far more valuable to you than the answers. Too many see an error, quickly scribble in the new answer and completely miss what they could learn from the process.
do you think i double counted or double subtracted. i.e their is a repeat somewhere, so i need to sibtract something e.t.c
i got an exam tommorow. if you have time. i kindly ask you tell me exactly what i did wrong so i can see the error, as i am kind of worried.
thanks again
OH i see what i did wrong. it should be (6C2)*(11C1)+(6C2)*(11C0)
thanks for your help
For question 2
***CORRECTIONS MADE***
Event 1= 2 chemist and 1 other=(6C2)*(11C1) =165
Event 2= 3 chemist and 0 other=(6C3)*(11C0) =20
NOT E=165+20=185
(Sample space-NOT E) = E=680-185=495.
495/Sample Space=Probability of E=495/680=99/136=72.79%
For question 3
NOT favour=(1 chemist + 1 bioligist + 1 physicists)
NOT favour=(6C1)(4C2) + (6C2)(4C1) +(6C3) + (6C2)(7C1) + (6C1)(7C1)(4C1)=36+60+20+105 + 168=389
Sample space - NOT favour = 680-389=291
291/680=42.79%
Final notes
What i have learnt
-Always check if the permutations add up to the sample size (in this case 17)
-Need to learn how a democracy works. If its a tie, then it doesn't pass/no favour
The problems worse for me because i have found in many exams when i see the answer in a calculator, i write another answer down on paper. E.g if i see 1723, i sometimes would write down 1273
"OH i see what i did wrong. it should be (6C2)*(11C1)+(6C2)*(11C0)"
Still not right.
"Event 1= 2 chemist and 1 other=(6C2)*(11C1) =165
Event 2= 3 chemist and 0 other=(6C3)*(11C0) =20"
Finally right.
"NOT favour=(6C1)(4C2) + (6C2)(4C1) +(6C3) + (6C2)(7C1) + (6C1)(7C1)(4C1)=36+60+20+105 + 168=389"
Still missing one case.
But at least it sounds like you are beginning to recognize the kinds of errors you make. That is a very good thing. Keep watching for the kinds of errors you make and what kinds of circumstances they show up in. And make yourself some rules that you will follow to help yourself catch and correct those mistakes.
Still not right.
Finally right.
yes, i am missing the case where their is "3 physicists"...i am so grateful for all your help.
you didnt need to take your time to help me, but still did. i can see that you are a decent person. i thank you for all your generosity up to now
thanks again
For question 3
NOT favour=(2 chemist + 1 bioligist)
NOT favour=(3 physicists)
NOT favour=(6C1)(4C2) + (6C2)(4C1) +(6C3) + (6C2)(7C1) + (6C1)(7C1)(4C1) + (4C3)=36+60+20+105 + 168 + 4=393
Sample space - NOT favour = 680-393=287
287/680=42.21%
Final notes
What i have learnt
-Need to learn how a democracy works (if no one votes, then no favour/no one wins)
  • · Replies 29 ·
