Help w/BWR Array: Guide Rods/Tubes in 8x8 Assembly
  • Thread starter Thread starter MuonSchmloun
    Array
The discussion clarifies that 8x8 BWR assemblies do not contain guide rods or instrumentation tubes, as these designs were phased out in favor of 9x9 and 10x10 fuel assemblies starting in the 1990s. The earliest 8x8 assemblies lacked water rods, while later designs introduced water channels to enhance moderation within the fuel rods. GNF's 10x10 designs utilize two water rods, AREVA employs a water box in their ATRIUM-10 designs, and Toshiba/Westinghouse incorporates a water cross with a diamond channel. Control elements are external to the assembly, with four assemblies surrounding each control rod blade.
  • Understanding of BWR (Boiling Water Reactor) fuel assembly designs
  • Familiarity with nuclear fuel moderation techniques
  • Knowledge of control rod mechanisms in nuclear reactors
  • Awareness of historical developments in nuclear fuel technology
  • Research the specifications of 9x9 and 10x10 BWR fuel assemblies
  • Explore the design features of GNF's 10x10 fuel assemblies
  • Investigate AREVA's ATRIUM-10 water box design
  • Learn about the operational principles of control rod blades in BWRs
Nuclear engineers, reactor designers, and professionals involved in the development and optimization of BWR fuel assemblies will benefit from this discussion.
MuonSchmloun
On a typical 8 x 8 BWR assembly which slots would contain guide rods, or instrumentation tubes?
None. Firstly 8x8 fuel was phased out starting around 1990 with the introduction of 9x9 fuel, and more recently, BWR 10x10 fuel designs have been introduced. The earliest 8x8 assembly had no water rods. In the late 70's and early 80's, BWR vendors introduced 8x8-1, then 8x8-2, and in the case of GNF and AREVA, during early to mid-80's, to 8x8-4 designs. ABB switched from 8x8 (SVEA-64) to 10x10 (SVEA-100, then SVEA-96) in the mid 90's while GNF and AREVA went to 9x9 designs, then 10x10 designs.
There are water rods/channels/crosses in BWR assembies, not guide tubes or instrument tubes. The objective is increased moderation in the interior fuel rods of the assembly.
GNF uses two water rods in their 10x10 designs, AREVA uses a water box (square channel) in their ATRIUM-10 designs, and Toshiba/Westinghouse (formerly ABB) uses a water cross or four-armed cruciform water channel with a square (diamond) channel in the center.
The BWR control elements are external to the assembly. Four assemblies surround one control rod (control rod blade (CRB) or control blade). Incore instruments are located at the corners of core cells (each cell representing 4 assemblies surrounding one CRB).
Please refer to:
http://www.westinghousenuclear.com/Products_&_Services/docs/flysheets/NF-FE-0011.pdf
http://www.westinghousenuclear.com/Products_&_Services/docs/flysheets/NF-FE-0015.pdf
http://www.areva-np.com/us/liblocal/docs/Brochure/Fuel/ANP_U_312_V1_09_ENG_atrium.pdf
http://www.fuel.ans.org/fuel10/high...l fuel design-I/1140 [Compatibility Mode].pdf - use save target as - available for a limited time
http://www.gepower.com/prod_serv/products/nuclear_energy/en/downloads/gnf2_adv_poster.pdf
http://www.gepower.com/prod_serv/products/nuclear_energy/en/downloads/gnfs2_adv_fact_sheet_final_usa.pdf
  • · Replies 25 ·
  • · Replies 0 ·
