Metacentric height correction due to free surface effect
The discussion centers on calculating the corrected metacentric height (GM) of a floating structure with an open compartment filled with water. The formula used is GMnew = GM - (density of tank fluid * acceleration of gravity * second moment of inertia / structure displacement). Two opinions arise regarding which second moment of inertia to use: one suggests using the moment of the free water surface with respect to its axis of transverse rotation, while the other proposes using the moment with respect to the structure's axis. The calculations provided yield two different corrected GM values: 1.66 m and 1.01 m, depending on the chosen moment of inertia.
  • Understanding of metacentric height and stability in floating structures
  • Knowledge of second moment of inertia calculations
  • Familiarity with fluid dynamics principles
  • Basic proficiency in structural engineering concepts
  • Research the impact of free surface effects on metacentric height calculations
  • Learn about the principles of buoyancy and stability in marine structures
  • Explore advanced calculations for second moments of inertia in fluid mechanics
  • Investigate software tools for simulating floating structures and stability analysis
Marine engineers, naval architects, and structural engineers involved in the design and analysis of floating structures and their stability under various loading conditions.
ar
Hi
regarding the above subject there is a conflict of opinion between me and a collegue. So i need your help
In order to calculate the corrected metacentric height of a floating structure that have a open compartment, filled with water, that is located eccentrically i have to use
GMnew = GM - (density of tank fluid * accel. of gravity * second moment of inertia / structure displacement)
Which is the second moment of inertia that i have to use?
My opinion : is the moment of the free water surface with respect to it's axis of transverse rotation
My collegues opinion : is the moment of the free water surface with respect to the structure's axis of transverse rotation
I will appreciate your reply
Thanks
ar
I'm a little ways away from my last statics/dynamics class and I'm not sure of all of your terms, so I'm not quite sure what you are asking, but perhaps drawing a simplified version of your problem would help:
A 2d, square-cross section ship with 4 compartments floats 3/4 of the way out of the water. If the bottom-right compartment is opened, it fills halfway and the moment generated on the ship can be calculated by using a point-force at the cog of the water in relation to the cog of the ship.
Dear russ_waters
thank you for your reply
I will try to make the problem more specific.
Let's say we have concrete box structure with plan dimensions 10m (transverse) & 20m(longitudinal) that is closed at the bottom with a slab and open on the top. The structure is divided in two symmetrical parts by a wall running on the longitudinal axis. So we have the concrete box structure with two empty tanks (20 by 5) that we are going to float (assume that height is sufficient, let's say 15m). The wall & slab thickness is, let's say 50cm.
Now we add 1m of water inside the two tanks.
Checking the transverse stability of the structure
Weight = 1880 tons (1440 ton walls + 240 tons slab +200 ton water)
Draft should be 1880/(20*10)= 9.4 m, for displaced volume = 1880 m3
Center of gravity located at 5.7m
Center of boyancy located at 4.7m
Now, let's calculate the following values
2nd moment of inertia of waterplane area Jw= 20 x 10^3/12 = 1667 m4
2nd moment of inertia of each tank free surface with respect to tank centerline Jf1 = Jf2 = 20 x 5^3/12 = 208 m4
2nd moment of inertia of each tank free surface with respect to structure's centerline Jf1' = Jf2' = (20 x 5^3/12) + (( 20 x 5) x 2.5^2)= 833 m4
Metacentric height without considering the free water surface effect will be
GM0=(J of waterplane area / displaced vol) + (5.7-4.7) = (1667/1880)+1 = 1.88 m
NOW, MY QUESTION IS
In order to consider the effect of free surfaces to the GM0 we have to reduce GMo by a value equal
a) (Jf1+Jf2)/displ volume = 2 x 208/1880 = 0.22m so the GMcorrect=1.66m
or
b) (Jf1'+Jf2')/dipl volume = 2 x 833/1880 = 0.87, so the GMcorrect=1.01 m
Thank you again for your interest to my inquiry
ar
36K
16K
  • · Replies 17 ·
