What is the Solution to a Classic Tension Problem Involving Ropes and Trees?
  • Thread starter Thread starter tictactony
    Tension
The discussion revolves around a tension problem involving a 22 kg pack suspended between two trees using ropes at angles of 71 degrees and 28 degrees. Participants are analyzing the forces acting on the pack and attempting to derive the tensions in the ropes.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculations for the tensions in the ropes, questioning the setup and the derived equations. There is an exploration of the relationship between the y and x components of the tensions and how they relate to the weight of the pack.
Several participants are engaged in clarifying the equations and the assumptions made in the problem. There is a focus on ensuring the accuracy of the derived equations and the interpretation of the angles involved. Some participants express confusion about the calculations and the implications of the results.
There is a mention of the need for clarity regarding the angles provided in the problem statement, as well as the significance of the calculated tensions in relation to the weight of the pack. Participants are also addressing potential miscalculations in the algebraic manipulation of the equations.
tictactony
A camper hangs a 22 kg pack between two trees, using two separate pieces of rope of different lengths, as shown in the figure below. (I don't know how to post the picture but I'm sure you can visualize two ropes and two trees with angle measures 71 left and 28 right)
Weight=mg
I'm pretty sure I know how to do this problem because I've done it before with easier numbers. I'm actually getting quite frustrated and I'm on my last guess wondering what the heck I'm doing wrong.
Using T1 as the tension in the left rope I calculated: T1*sin(71)=T1y
T2 tension in the right: T2*sin(28)=T2y
then I know both these y components have to add up to 215.6 N because (22kg)(9.8m/s^2) yields the gravitational force on the pack.
Next I did the x components and got:
T1*cos(71)=T1x
T2*cos(28)=T2x
Since the pack is stationary I know the x components have to be equal.
I'm left with a system of equations and after eliminating T2 I'm left with
T1=(215.6)/(sin(28)) / ((sin(71))/(sin(28))+((cos(71))/(cos(28)))
T1=(215.6)/(sin(28)) / (sin(71)+tan(28)*cos(71))
T1=766.696 which I KNOW is incorrect because that exceeds the weight of the pack
tictactony said:
A camper hangs a 22 pack
That's 22 kg you meant, right?
Where did 71 and 28 come from?
T1*cos(71)=T1x
T2*cos(28)=T2x
I don't follow how you got that by combining the previous equations.
Why can't the tension be greater than the weight of the pack?
The sin(28) in the second line shouldn't be there anymore.
Answering your questions diazona,
yes 22 kg my mistake
the 28 and 71 are the angle measures
and lastly, they can it just looks like a ridiculously high amount for a 22kg.
And fzero, when I eliminated the T2 from the system of equations I had to divide all the parts of the 1st equation by sin(28) and all the parts of the second by cos(28)
Were 28 and 71 were given in the problem? If so, you should have included them in the problem statement.
Anyway, I misformatted my post so you might have missed the main question: how exactly did you get this equation?
T1sin(71) + T2sin(28) = 215.6N
T1cos(71) - T2cos(28) = 0N
Then divided the top equation by sin(28) and the bottom by cos(28) to get
T1[sin(71) / sin(28)] + T2 = 215.6 / sin(28)
T1[cos(71) / cos(28)] - T2 = 0
Then added them together to get
"T1=(215.6)/(sin(28)) / ((sin(71))/(sin(28))+((cos(71))/(cos(28)))"
That's not what you get when you add the two equations together. Go back and do that step again, more carefully this time.
I just did it again and got the same thing, what am I doing wrong? The T2's cancel...
Looking at it again, I might have miscounted the parentheses. You have far more than necessary in there so it gets rather confusing. (Last time I double-checked my count but I guess I made the same mistake every time I read it)
Anyway, if the parentheses are in the right places, everything seems to be in order.
9K
