Addition of Vectors: Finding the Angle
  • Thread starter Thread starter Haftred
    Addition Vectors
The problem involves the addition of vectors, specifically a horizontal force and another force acting at an angle. The original poster seeks to determine the resultant vector's magnitude and angle based on the given forces.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate the resultant vector's magnitude and is uncertain about how to find the angle using inverse tangent. Some participants suggest breaking down the vectors into their components and using trigonometric methods to find the resultant vector.
Participants are engaged in exploring different methods to approach the problem, with some providing guidance on using vector components and trigonometry. There is an ongoing exchange of ideas, but no explicit consensus has been reached on the best method to find the angle.
Participants note the importance of considering additional degrees when using trigonometric functions and the potential need to adjust angles based on the direction of movement. There is an acknowledgment of the roughness of sketches used to illustrate points.
Haftred
One of my review questions is the following:
"A box is pulled along the floor by a horizontal force of 35 N. Another force acts concurrently on the box with a force of 25 N at an angle of 40 degrees above the horizontal in the same direction as the first force. What is the sum of the two vectors?"
I got the magnitude of the vector to be 56 N by finding the square root of the horizontal and vertical components respectively squared. However, how does one find the angle. I know I need to calculate the inverse tangent of something - but what?
Try breaking the vectors down into their x and y components. Then find the sum of the x components, then the sum of the y components. Then, draw a triangle with these vector sums and use trig to find the resultant vector.
thanks...I'll definitely do better on the exam now :cool:
glad I could help! :smile:
note be sure to add in the extra degres when using a triangle for trig
you can solve for the angle but then you may need to add/subtract 90,180,270,360
example
--------------=-------------------- ROUGH DRAWING
--------------=-------------------- VECTOR ONE= positive x
--------------=-------------------- VECTOR TWO= negitive y
============AAAAAAAAAAAAAAA
--------------A-A------ If you solve for this angle and you have
--------------A-- A----------counterclockwise movement then you must
--------------A----- A------- subtract 360 to get angle
--------------A-------- A
I hope this makes sense
i know it is very rough sketch
  • · Replies 21 ·
  • · Replies 38 ·
9K
