| New Reply |
Integration in Sean Carroll's "parallel propagator" derivation |
Share Thread | Thread Tools |
| Nov4-10, 01:48 PM | #1 |
Reading Chapter 3 of Sean Carroll's General Relativity Lecture Notes, I've followed it up to and including eq. 3.38.
[tex]\frac{d}{d\lambda} P^\mu_{\;\;\; \rho}(\lambda,\lambda_0) = A^\mu_{\;\;\; \sigma} P^\sigma_{\;\;\; \rho}(\lambda,\lambda_0).[/tex] Here, Carroll writes, "To solve this equation, first integrate both sides: [tex]P^\mu_{\;\;\; \rho}(\lambda,\lambda_0) = \delta^\mu_\rho + \int_{\lambda_0}^\lambda A^\mu_{\;\;\; \sigma} (\eta) \; P^\sigma_{\;\;\; \rho}(\eta,\lambda_0) \; d \eta.[/tex] "The Kronecker delta, it is easy to see, provides the correct normalization for [itex]\lambda = \lambda_0[/itex]." I can see that this makes P the identity matrix in that case, but by what algebraic rule is it inserted. This is a definite integral, so shouldn't any constant of integration be cancelled out? Also, I don't understand the iteration procedure that follows. Doesn't the concept of integration already encode such a procedure, taken to a limit? Should I read this as (coordinate-dependent?, coordinate independent?) abstract index notation for a matrix equation inside the integral sign, or is each component function integrated separately? Is there a name for this procedure or the subject area that includes it? Can anyone recommend a book or website that explains the mathematical background. Sorry these questions are a bit vague. I'm not really sure what to ask. I wonder if it's related to what Bachman calls cells and chains. Maybe I should read the rest of that chapter first. |
| Nov5-10, 03:46 AM | #2 |
Write it as
[tex]\frac{dP(\lambda)}{d\lambda}=A(\lambda)P(\lambda)[/tex] The solution of this differential equation with the initial data [tex]P(\lambda_0)=I[/tex] is [tex]P(\lambda)=I+\int_{\lambda_0}^\lambda A(\lambda)P(\lambda)[/tex] First, check that indeed the initial value data are satisfied and then that the differential equation is also satisfied. Now, add the indices remembering that [tex]\left(\frac{dP(\lambda)}{d\lambda}\right)^\mu_\rho[/tex] is the same as [tex]\frac{dP^\mu_\rho(\lambda)}{d\lambda}[/tex] and similarly on the RHS - matrix entries of the integral are integrals of matrix entries owing to the linearity of the integral. That is how we define derivatives and integrals of vector-valued functions. |
| Nov5-10, 05:39 PM | #3 |
Thanks again, arkajad! I get it now. Holding lambda_zero constant,
[tex]P(\lambda) - P(\lambda_0) = \int_{\lambda_0}^{\lambda} A(\eta) P(\eta) \; \mathrm{d}\eta[/tex] and [tex]P(\lambda_0) = I[/itex] given what the parallel propagator has be defined to do, so [tex]P(\lambda) = I + \int_{\lambda_0}^{\lambda} A(\eta) P(\eta) \; \mathrm{d}\eta.[/tex] Sean Carroll's eq. (3.39) is just this expressed with indices. And there's no ambiguity over the order of operations, because the derivatives and integrals are defined componentwise. |
| New Reply |
| Thread Tools | |
Similar Threads for: Integration in Sean Carroll's "parallel propagator" derivation
| typo in "Kapusta" or "Ashok Das"? Formula for thermal propagator | Quantum Physics | 0 | ||
| Derivation of General from "maximum force principle", Review of this method | General Physics | 0 | ||
| Sean Carroll | General Astronomy | 6 | ||
| Sean Carroll Cosmology Primer | General Astronomy | 12 | ||
| Sean Carroll on the debate | Current Events | 1 | ||
