Does G with all its degrees at least three contain a cycle with a chord?
The discussion revolves around the problem of proving that a graph G, where all vertices have degrees of at least three, contains a cycle with a chord. The scope includes theoretical reasoning and mathematical proof strategies.
  • Exploratory, Technical explanation, Debate/contested, Mathematical reasoning
  • One participant suggests using induction on the number of vertices in G, noting that for n >= 4, the assertion might hold but encounters difficulties when some vertices have degree two.
  • Another participant proposes a proof by contradiction involving a maximal chordless cycle, while acknowledging the complexity introduced by the presence of bridges or 2-edge cutsets.
  • A third participant references a proof found in Lovasz's textbook, describing a method involving a maximal path and demonstrating that a vertex with degree at least three must connect to non-adjacent vertices, thus forming a cycle with a chord.
  • A fourth participant shifts the focus to seeking tutoring assistance for geometry theory, which appears unrelated to the main discussion.
Participants express differing approaches to the problem, with no consensus reached on a single method of proof. The discussion includes both exploratory ideas and references to established proofs, indicating a variety of perspectives.
Some participants note challenges related to specific cases, such as the presence of bridges or 2-edge cutsets, which complicate the proof process. Additionally, the induction hypothesis relies on assumptions about vertex degrees that may not hold in all scenarios.
Readers interested in graph theory, mathematical proofs, or those seeking to understand the complexities of cycles in graphs may find this discussion relevant.
MathematicalPhysicist
Let G be a graph with all its degrees at least three.
Show that G contains a cycle with a chord (a chord is an edge which connects two non-adjacent vertices on the cycle).
I thought of proving this by induction on the number of vertices of G, but I am stuck.
Obviously, n>=4 otherwise it couldn't have all its degrees at least three.
So now I assume by induction that this assertion is true for every number smaller than n (until 4), and I want to prove that this assertion is valid also for graph G with n vertices.
So if I build a new graph with taking out one vertex from G with its edges, I get a new graph, G' with n-1 vertices and it has vertices which are for sure at least have degrees two, if all of them have degree at least three then by the induction hypothesis I prove the assertion cause by adding the vertex I still have a cycle with a chord from the graph G', the problem of mine is when some of the vertices have degrees two.
Somehow I want to use a reduction that in the worse case scenraio I arrive at a case with 4 vertices and all of its degrees are at least three which guarantee a cycle with at least one chord.
Don't know how to show this?
Any hints?
Maybe a proof by contradiction involving a maximal chordless cycle, but still tricky to consider the cases where G has a bridge or a 2-edge cutset.
Ok, I found a proof of this in Lovasz's textbook.
The proof goes as follows:
Let P=(x0,...,xm) be a maximal path in this graph, now because x0 has degree of at least three its other neighbours must be in this path or otherwise we can find another maximal path in contrary to our assumption.
so x0 for example has at least another two neighbours besides x1 on this path, say for 1<i<j<= m it has two neighbours xi and xj.
So the cycle (x0,...,xj) contains a chord namely (x0,xi).
Thank you, Lovasz!
i have many problems in geometry theory...please can anyone suggest me the best and experienced tutor for math.
http://fruition.com.au/"
