1/4th Life expression for First Order Rxn
The discussion focuses on deriving the 1/4th life expression for a first-order reaction using the equation ln([A]₀/[A]ₜ) = kt. Participants clarify that the "1/4" in t₁/₄ represents the fraction of reactant remaining, not a time value. The correct expression for t₁/₄ is derived as t₁/₄ = ln(4)/k, which simplifies to approximately 1.386/k. Misinterpretations regarding the use of "1/4" as a time variable were addressed, emphasizing the importance of correctly identifying variables in chemical kinetics.
  • Understanding of first-order reaction kinetics
  • Familiarity with natural logarithms and their properties
  • Basic knowledge of chemical reaction equations
  • Ability to manipulate algebraic expressions
  • Study the derivation of first-order reaction rate laws
  • Learn about the concept of half-life and its relation to reaction kinetics
  • Explore the application of the Arrhenius equation in reaction rates
  • Investigate the impact of temperature on reaction kinetics
Chemistry students, educators, and professionals in chemical engineering or related fields who are looking to deepen their understanding of reaction kinetics and mathematical modeling of chemical processes.
[V]
I must derive the 1/4th life expression for a first order rxn.
[tex]ln(\frac{[A]_{\circ}}{[A]_{t}})=kt[/tex]
[tex]ln(\frac{[A]\circ}{\frac{1}{4}[A]_{\circ}})=kt_\frac{1}{4}[/tex]
[tex]ln(4)=kt_{\frac{1}{4}}[/tex]
do I set t=1/4 ?
[tex]\frac{ln(4)*4}{k}[/tex]
[tex]\frac{5.545}{k}[/tex]
What am I doing wrong here? The answer is allegedly 1.386/k
However, this answer key has been wrong before. Can someone please confirm/deny this?
Thank you
Chemistry news on Phys.org
You are asked to calculate [itex]t_{\frac 1 4}[/tex] as a function of k, you can't assume t=0.25 and put it into equation. You need answer in form t=some expression, where is t in your final answer?<br /> <br /> <blockquote data-attributes="" data-quote="[V];2971106" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> [V];2971106 said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> [tex]ln(4)=kt_{\frac{1}{4}}[/tex] </div> </div> </blockquote><br /> Up to here you were right, just solve for [itex]t_{\frac 1 4}[/tex].[/itex][/itex]
hi [V]! :smile:
[V];2971106 said:
do I set t=1/4 ?
nooo, 1/4 isn't time, it's amount (of reactant used) …
the "1/4" in t1/4 is only a label, to remind you that it corresponds to 1/4 of the reactant being used :wink:
you're correct up to ln(4) = kt1/4,
now just say t1/4 = … ? :smile:
  • · Replies 131 ·
11K
