How Do You Calculate the Maximum Height of an Object Thrown Vertically Upward?
  • Thread starter Thread starter kimikims
The problem involves calculating the maximum height of an object thrown vertically upward, given its speed at a specific height and the acceleration due to gravity. The context is kinematics, focusing on motion under gravity.
  • Participants discuss the use of kinematic equations to relate the speed of the object at two-thirds of its maximum height to the maximum height itself. There are questions about isolating variables in the equations and clarifying the initial conditions of the motion.
Some participants have provided guidance on manipulating the equations to isolate the variable for maximum height. There is an ongoing exploration of the initial conditions, particularly regarding the initial speed of the object and how it relates to the motion during ascent and descent.
Participants are navigating assumptions about the initial speed of the object and the implications of analyzing the motion during both ascent and descent. There is a focus on understanding the setup of the problem and the application of kinematic principles.
kimikims
An object is thrown vertically upward such that it has a speed of 58 m/s when it reaches two thirds of it's maximum height above the launch point.
The acceleration of gravity is 9.8 m/s^2
Find the maximum height h. Answer in units of m.
I know:
V: 58 m/s at y=2/3 H
H = ?
V = 0
V^2-Vo^2 = 2g(1/3H)
I know I need to plug in the numbers, but how do I get all of the equation to one side, to find H??
kimikims said:
V^2-Vo^2 = 2g(1/3H)
Right (where Vo = 0).
Divide or multiply both sides to eliminate what's in front of H.
For example, if you had an equation: 7x^2 = 67bZ, and you wanted to isolate Z, just divide both sides by 67b: (7x^2)/67b = (67bZ)/67b = Z; so Z = (7x^2)/67b. Make sense?
You got
[tex]V^2 = V_{o}^2 + 2g\frac{2}{3}H[/tex]
where V is 58 m/s
and
[tex]0 = V_{o}^2 + 2gH[/tex]
Doc Al, how come initial speed = 0 ?
If you look at the motion on the way down, then the object starts from rest and falls a distance of H/3 to reach a speed of 58 m/s.
Oh Yes, i wasn't thinking about it :biggrin:
  • · Replies 38 ·
  • · Replies 25 ·
12K
