Position of Ball w/ Initial Velocity 10 m/s After 2.12794 s
The discussion focuses on calculating the position of a ball with an initial velocity of 10 m/s after 2.12794 seconds under the influence of gravity (9.8 m/s²). For a downward throw, the formula used is y = 10t - 4.9t², resulting in a position of approximately 43.47 m. For an upward throw, the same formula applies, but the gravitational acceleration is negative, leading to a different outcome. The correct interpretation of vector direction is crucial in these calculations.
  • Understanding of kinematic equations
  • Basic knowledge of vector components
  • Familiarity with gravitational acceleration
  • Ability to perform quadratic calculations
  • Study kinematic equations in physics
  • Learn about vector analysis and directionality
  • Explore the effects of different initial velocities on projectile motion
  • Practice solving problems involving gravitational acceleration
Students studying physics, educators teaching kinematics, and anyone interested in understanding projectile motion and gravitational effects.
kimikims
A ball has an initial velocity of 10 m/s.
The acceleration of gravity is 9.8 m/s^2.
What will be it's postion after 2.12794 s if it is throw
a) down with an initial velocity of 10 m/s? Answer in units of m.
b) up with an initial velocity of 10 m/s? Answer in units of m.
I think for b you use:
y = volt + 1/2gt^2
I got 43.47m, but that's wrong.
I got -1.03, i think your calculations are wrong, and also i forgot if its negative it's pointing down, so it's going down.
use this : y = 10t - 9.8t²/2 and the t is given
the g-vector points downwards the y-axis thus you need to write a minus sign. Watch out when you work with vectors : you have the magnitude of a vector AND the direction of a vector...
marlon
  • · Replies 19 ·
  • · Replies 17 ·
