Finding the Function for 3/2(g(x))^2: Proving 3/2(g(x))^2 = g''(g)
  • Thread starter Thread starter monsmatglad
    Function
The discussion revolves around finding a function that satisfies the equation 3/2(g(x))^2 = g''(g), where g is suggested to be the inverse of a function f defined by an integral. The problem is situated within the context of calculus, particularly focusing on derivatives and inverse functions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the relationship between the functions f and g, questioning how g relates to f and the meaning of g''(g). There are attempts to differentiate f and apply the chain rule to find g'(x) and g''(x). Some participants express confusion about the definitions and relationships involved, particularly regarding the derivatives of inverse functions.
Several participants have offered guidance on differentiating the functions and applying the chain rule. There is an ongoing exploration of the relationships between the derivatives of f and g, with some participants expressing uncertainty about their calculations and definitions. The discussion is active, with participants iterating on their understanding and clarifying concepts.
Participants note difficulties in aligning their results and understanding the implications of their calculations. There is a recognition of the need for precision in the definitions and arguments of the functions involved, as well as the potential for numerical checks to validate their analytical approaches.
monsmatglad
i want to find the function that satisfies the below. been trying a lot, but all my tactics have proven useless.
f:[0,=>] -> R
f(x)= [0]\int[/x]( 1/(1+t^3)^0.5)
show that 3/2(g(x))^2 = g''(g)
f:[0,=>] -> R
How does g(x) enter the picture? How is it related to f(x)? What does g''(g) mean?
Sorry for not being precise. g''(g) was supposed to be g''(x), the second derivative of g. The function g is not really mentioned any further in the assignment, but I'm pretty sure it's the inverse function of f.
Mons
f:[0,=>] -> R
I'd first make sure it's right Mon. How about I write it as:
Let:
[tex]y=f(x)=\int_0^x \frac{1}{\sqrt{1+t^3}}dt[/tex]
Then if:
[tex]x=f^{-1}(y)[/tex]
show:
[tex]3/2(f^{-1}(y))^2=\frac{d^2 f^{-1}}{dy^2}[/tex]
I dont' know how to do that right off-hand analytically but I do know how to check it numerically. I'll leave this Mathematica code for you to interpret if you're interested:
Code:
f[x_] := NIntegrate[1/Sqrt[1 + t^3],
    {t, 0, x}];
mytable = Table[{f[x], x},
    {x, 0, 1, 0.01}];
myeqn = Table[x^n, {n, 0, 10}]
myfit = Fit[mytable, myeqn, x]
p1 = Plot[(3/2)*myfit^2, {x, 0, 1},
   PlotStyle -> Red]
p2 = Plot[Evaluate[D[myfit, {x, 2}]],
   {x, 0, 1}, PlotStyle -> Blue]
Show[{p1, p2}]
And the reason for doing that is to give me some assurance that the problem is even written correctly and now that I know it's probably correct (at least in the range I checked it), it's worth working on to try and prove it analytically.
Ok, I see it. How about you start with just differentiating f(x) and recall that the derivative of the inverse is:
[tex]\frac{dx}{dy}=\frac{1}{\frac{dy}{dx}}[/tex]
Now what can you think to do?
Hm. I've been trying to diferentiate and integrate g(x), but the numbers don't seem to add up? did they for you? please show me the way=).
Here's what jackmell is saying in different notation. Since f and g are inverses, f(g(x))=x. If you differentiate that using the chain rule, you get f'(g(x))*g'(x)=1, right? Can you apply that to this problem? What's f'(g(x))?
hm, that's actually what I've been doing, but with no luck. i get that g'(f(x))=(1+x^3)^0.5
and f'(g(x)) is 1/((1+t^3)^0.5)
That's somewhat messed up. f'(g(x)) doesn't have a t in it. How can what it is equal to be a function of t? Can you run through how you got f'(g(x)) again?
sorry. f'(x) must be 1/(1+x^3)^0.5. and according to the rule which i don't know what is called, the derivative of g(f(x)) is 1/f'(x). this is what i have been using, but with no success. i don't get the answers to fit together like they should.
You have to be more careful about the arguments of the functions. You are being too sloppy. Yes, f'(x) is 1/(1+x^3)^(1/2). No, the derivative of g(f(x)) is NOT 1/f'(x). g(f(x))=x. I'd say the derivative of x is 1.
ok. but what do you get when you derivate g(f(x)) in this problem? I see I've been thinking the wrong things, but i really believe i just need to see the correlation, and then i will understand.
You start with the expression I mentioned before. Since g and f are inverses, f(g(x))=x, correct? Can you differentiate both sides of that expression? If you can, you can find g'(x) in a useful form.
hm, yes. f(g(x)) = x. f'(g(x))*g'(x)=1. but even though I've been using the wrong definitions, i think what i now get is sort of similar to what I've tried.
That's right. If that's similar to what you've tried, then you were on the right track. Now solve for g'(x) and use your expression for f'.
yes. but this is really where my tactics failed. i get thet g'(x)= (1+x^3)^0.5 and when i integrate and derivate this, the results don't fit like the are supposed to.
That's because you did something wrong in solving for g'(x). What is f'(g(x))?
hm, f'(g(x)) is 1/(1+x^3)
That is f'(x) (well, it is if you stick the 0.5 power in). That is NOT f'(g(x)).
hm, i guess this is what made me fail. and i really don't know what f'(g(x)) is.
It's easier than you think. f'(x)=1/(1+x^3)^(1/2). Substitute 'g(x)' for 'x'. That's all.
so f'(g(x)) is 1/(1 + g(x)^3 )^(1/2). ?
Sure it is. Getting the arguments of functions right isn't that hard. So now what's g'(x)?
(1+g(x)^3)^0.5 i guess =)
Yes, it is. Can you finish it off? What's g''(x)?
(3/2)*g(x)^2*(1+g(x)^3)^-0.5
You are missing something. You didn't finish with the chain rule. Where's the g'(x) on the right side?
g'(x)*(3/2)*g(x)^2*(1+g(x)^3)^-0.5?
yes, that must be it
I hope that '?' doesn't mean you don't know why there should be a g'(x).
  • · Replies 28 ·
