Torque Problem, acceration of mass. Help
  • Thread starter Thread starter mmmboh
    Mass Torque
The discussion revolves around a torque problem involving a cylinder and a mass connected by a string. Participants explore the dynamics of the system, particularly focusing on the relationships between tension, torque, and acceleration.
  • Mixed
  • Participants discuss the effects of tension on the cylinder and question whether certain forces exert torque. There are attempts to derive equations relating tension, acceleration, and torque, with some expressing confusion about the implications of mass and tension on the system's motion.
Some participants have provided insights into the relationships between the forces and torques, while others express uncertainty about their equations and the assumptions being made. Multiple interpretations of the problem are being explored, particularly regarding the motion of the cylinder and the mass.
There are discussions about the assumptions of massless strings and the implications of different tensions on either side of the cylinder. Participants also note the need for additional equations to resolve the unknowns in their analysis.
mmmboh
[PLAIN]http://img825.imageshack.us/img825/4091/cylindera.jpg
I have solved problems like this before, but they have all been, well atwoods, and the disk in that case can't move translationally.
So at the top of the cylinder the tension in the string is T, and so that exerts a torque of T*r on the cylinder. Now I call the tension at the string where the mass m is t, I know t=ma. Now I believe this doesn't exert a torque on the cylinder because it is an internal force, or something, or because the mass m is what allows the tension to be T at the other side of the rope (if there was no mass m, then there wouldn't be a T at the other side). so T*r=I[tex]\alpha[/tex]...I know I=0.5mr2, and that there is no slipping, so I think that since the cylinder also moves translationally, the equation is something like
(astring-acylinder)=r*[tex]\alpha[/tex]...however this doesn't seem quite right to me because the string doesn't really move uniformly if the cylinder is moving, like the string near the mass m won't even move for a while if the cylinder moves a lot, but the string on the other side will...
Anyway because of this I'm not exactly sure what to do. Can anyone help please?
hi mmmboh!:smile:
(have an alpha: α and a tau: √ :wink:)
mmmboh said:
… I know t=ma. Now I believe this doesn't exert a torque on the cylinder because it is an internal force, or something, or because the mass m is what allows the tension to be T at the other side of the rope (if there was no mass m, then there wouldn't be a T at the other side). so T*r=I[tex]\alpha[/tex] …
no, t is external both to the cylinder and to the little mass m …
(it is only internal if you regard both masses as a single body)
… so tr is part of the torque :wink:
and you need two equations for T and t …
a standard linear F = ma for the linear motion of the c.o.m. of the cylinder,
and a τ = Iα for the rotation of the cylinder about its c.o.m.
Well I get (T+t)=ma (I have a problem with this equation though, because if there were no mass m attached then the cylinder wouldn't rotate or move, but this equation predicts it would I think) and (T-t)r=Iα=I*a/r.
Solving I get t=T/2 and for acceleration I get a=T/m, which is the acceleration of the cylinder, but not the mass. So then since t=T/2=mamass...so amass=T/2m... I don't know, that means that if the mass were 0 it would have an infinite acceleration, doesn't make sense..but if the mass were zero wouldn't the tension be zero...I must be missing something.
it would rotate, because the rope doesn't slip :wink:
… and (T-t)r=Iα=I*a/r.
Solving I get t=T/2 and for acceleration I get a=T/m, which is the acceleration of the cylinder, but not the mass. So then since t=T/2=mamass...so amass=T/2m... I don't know..
I'm not convinced … what I are you using? :confused:
I=mr2/2
I said T-t=0.5ma=(T+t)/2, and solved for t like that.
anyone?
(just got up :zzz: …)
mmmboh said:
… I get t=T/2 …
mmmboh said:
I=mr2/2
I get t = T/3, not T/2 :confused:
Ya, you're right, my mistake. So then a=T/3m...hmm...one thing though, since the rope is massless, the net tension everywhere should be zero so that it doesn't undergo infinite acceleration...but if the tension on one side of the rope is different than on the other side, how is this resolved?
the cylinder is rough, and the friction prevents the rope from slipping
the friction supplies the difference in tension, to make the net force zero :wink:
Ah thanks!..Sorry one more thing, why in this case does α=acylinder/r...shouldn't α=(astring-acylinder)/r to make it not slip? because the relative acceleration of the string to the cylinder is what matters...For instance if the acceleration of the cylinder was equal to the acceleration of the string, then the cylinder wouldn't need to rotate at all and the string still wouldn't slip.
no, if the string is not slipping, then the speed of the string equals the speed of the rim of the cylinder (and so also the acceleration of the string equals the acceleration of the rim of the cylinder) :smile:
Right but, in my equation T-t=0.5ma, that acceleration is the radial acceleration of the rim of the cylinder, so the acceleration of the string, but in my F=ma equation, I had T+t=ma, where this a is the translational acceleration of the cylinder...but to get t=T/3 I equated these equations, but that must mean that the radial acceleration of the rim is equal to the translational acceleration, I don't understand why this must be in this case. Because if the translational acceleration is equal to the acceleration of the string, then the rim will still be moving at the speed of the string, but it will have no radial acceleration.
oh sorry, I'd completely forgotten that the cylinder was moving (I was thinking of a similar question in another thread)
yes, you're right, it is α=(amass-acylinder)/r :smile:
Doesn't α=(astring-acylinder)/r? (by astring I mean the part that is being pulled) not (amass-acylinder?)/a I mean if anything it would be (amass+acylinder)/r since they are moving in opposite directions, but then again the cylinder can move without the mass moving can't it? This is why I was confused on how to solve it.
hi mmmboh! :smile:
it's best to use amass, because the mass comes into another equation, while the pulling end of the string doesn't.
let's see … is it + or - ? …
let's concentrate on B, the bit of the cylinder nearest us at the start (and we'll call the mass A and the cylinder C) …
then when the cylinder has rotated an angle θ, B has moved θ clockwise, and the string has moved with it, so the string is now rθ nearer the mass A,
so Ax - Cx = constant minus rθ,
so amass - acylinder = -rα :wink:
Hm ok so now I have 3 unknowns (t,acylinder,amass), but I only have two equations, I solved T=0.25m(amass+acylinder), but I need another equation to get rid of acylinder :confused:
One other thing, I don't quite get why Ax - Cx = k-rθ (k would be the original distance between them is what I assume you mean the constant to be), because the cylinder moves also...like if the cylinder just rotated I would get the equation, because the change in position of the mass and cylinder relative to each other would just be how much string gets wrapped around the cylinder, but in this case the cylinder is moving, so don't you have to take into account how much it moves translationally?
hi mmmboh! :smile:
no, you should have three equations …
the linear equation, the torque equation, and the constraint equation :smile:
that's what Cx is …
x-component of the (Centre of the) Cylinder! :wink:
I'm sorry, I feel stupid but I don't really understand. I know that Cx is the x-component of the center of mass, my issue is why Ax-Cx=k-rθ...Because let's say the center of mass of the cylinder doesn't move, then k-rθ is how much closer the mass is to the cylinder, in other words then Ax-Cx=k-rθ..but let's say the cylinder rotates that same amount, but this time Cx also moves, then the equation would predict the same result, but obviously it's not the same because now the cylinder is closer to the mass...
Sorry, but what is my constraint equation?
I have never had this much trouble understanding a problem :confused:
Thanks for your help by the way.
mmmboh said:
… let's say the cylinder rotates that same amount, but this time Cx also moves, then the equation would predict the same result, but obviously it's not the same because now the cylinder is closer to the mass...
no, because the mass has also moved, in this case the same amount as the cylinder (if the rotation is the same) :smile:
Ax - Cx = k - rθ …
a constraint equation is a geometrical equation rather than a force equation … like a body being constrained to move along a particular surface, or in this case the free length of string being constrained to be connected to the position and rotation of the bodies :wink:
Ok but, I used that constraint equation already to find α to plug it into my torque equation...
The three equations are T+t=ma
(T-t)r=Iα=0.5mr2α
Ax - Cx = k - rθ, so differentiating this twice I can solve for α.
So I get T+t=macylinder, and T-t=0.5m(acylinder-amass), and then I'm stuck.
ah, but you also have t = -mamass :wink:
  • · Replies 21 ·
  • · Replies 45 ·
