How can I use physics to determine the inclination of a tilted air hockey table?
  • Thread starter Thread starter Coolbass04
    Air Table
The discussion focuses on determining the inclination of a tilted air hockey table using physics principles. A physics student observes that a puck, given an initial velocity of 3.82 m/s along a 1.76 m table, drifts 2.59 cm to the right by the time it reaches the opposite end. The student correctly concludes that the table is not level and calculates its inclination based on the drift and the puck's velocity. Key steps include calculating the time taken for the puck to traverse the table and using trigonometry to analyze the effects of gravity on the puck's motion.
  • Understanding of basic kinematics, including velocity and acceleration
  • Knowledge of trigonometry for resolving components of forces
  • Familiarity with the concept of frictionless surfaces in physics
  • Ability to apply equations of motion under constant acceleration
  • Calculate the time taken for the puck to travel 1.76 m at 3.82 m/s
  • Learn how to resolve forces using trigonometric functions
  • Study the equations of motion for objects under constant acceleration
  • Explore the principles of inclined planes and their effects on motion
This discussion is beneficial for physics students, educators, and anyone interested in applying physics concepts to real-world scenarios, particularly in analyzing motion on inclined surfaces.
Coolbass04
I've been at this dang problem for 4-5 hours now. Still can't understand how to do it. Anyone have any hints or pointers of where to begin, or what to do??
A physics student playing with an air hockey table (a frictionless surface) finds that if she gives the puck a velocity of 3.82 m/s along the length (1.76 m) of the table at one end, by the time it has reached the other end the puck has drifted a distance 2.59 cm to the right but still has a velocity component along the length of 3.82 m/s. She concludes correctly that the table is not level and correctly calculates its inclination from the above information.
That is all the information that is given. Thanks in advance for your help.
You have a distance and a velocity...this means you can calculate a time. :wink: :wink: :wink:
Fun question. Ok well you know since it's a frictionless surface then the slide to the right is entirely due to gravity. However, you have to do a little trig to see exactly how much of the components of gravity are affecting the puck. The first step would be to figure out exactly how much time it took to get to the end of the table. Now that you have a time you can do a few more things. You know that since gravity is accelerating the puck a little to the right that it is under a constant acceleration. Given a position and a time and constant acceleration, you can determine exactly what that acceleration is. That should get the ball rolling in the right direction.
9K
