Calc 2 prove the series is itself
  • Thread starter Thread starter brushman
    Calc 2 Series
The discussion focuses on proving that the Maclaurin series generated by a power series, defined as \( f(x) = \sum_{n=0}^\infty a_n x^n \), is equivalent to the series itself within its radius of convergence \( c > 0 \). Participants highlight that the Maclaurin series is defined as \( \sum_{n=0}^{+\infty} \frac{f^{(n)}(0)x^n}{n!} \) and emphasize the need to demonstrate that \( a_n = \frac{f^{(n)}(0)}{n!} \). The discussion also notes that series derived from functions like \( x\sin(x) \) and \( x^2e^x \) maintain this property through operations such as multiplication, integration, and differentiation.
  • Understanding of power series and their convergence
  • Familiarity with Maclaurin series and Taylor series concepts
  • Basic knowledge of calculus, particularly differentiation and integration
  • Ability to manipulate series and apply definitions rigorously
  • Study the properties of power series and their convergence criteria
  • Learn how to derive Maclaurin series for various functions
  • Explore the relationship between differentiation and integration of power series
  • Investigate examples of functions whose series converge to their Maclaurin series
Students of calculus, particularly those studying series and convergence, as well as educators seeking to clarify the relationship between power series and their Maclaurin representations.
brushman
A function defined by a power series [itex]\sum_{n=0}^\infty \(a_{n}x^n[/itex] with a radius of convergence [itex]c > 0[/itex] has a Maclaurin series that converges to the function at every point of [itex](-c, c)[/itex]. Show this by showing that the Maclaurin series generated by [itex]f(x) = \sum_{n=0}^\infty \(a_{n}x^n[/itex] is the series [itex]\sum_{n=0}^\infty \(a_{n}x^n[/itex] itself.
An immediate consequence of this is that series like
[tex]x\sin(x) = x^2 - \frac{x^4}{3!} + \frac{x^6}{5!} - \cdot \cdot \cdot[/tex]
and
[tex]x^{2}e^{x} = x^2 + x^3 + \frac{x^4}{2!} + \cdot \cdot \cdot[/tex]
obtained by multiplying Maclaurin series by powers of x, as well as series obtained by integration and differentiation of convergent power series, are themselves the Maclaurin series generated by the functions they represent.
So I don't even know what to do. It seems like the Maclaurin series already equals itself by definition.
The MacLaurin series of a function f is defined as
[tex]\sum_{n=0}^{+\infty}{\frac{f^{(n)}(0)x^n}{n!}}[/tex]
So given a function [tex]f(x)=\sum_{n=0}^{+\infty}{a_nx^n}[/tex], you'll need to prove that [tex]a_n=\frac{f^{(n)}(0)}{n!}[/tex].
