Rigid equilibrium question involving a ladder...
by LizzleBizzle
Tags: homework, ladder, rigid equilibrium, torque
LizzleBizzle
LizzleBizzle is offline
#1
Nov9-10, 02:32 PM
P: 3
"Three people are carrying a horizontal ladder 4.00 m long. One of them holds the front end of the ladder, and the other two hold opposite sides of the ladder the same distance from its far end. What is the distance of the latter two people from the far end of the ladder if each person supports one-third of the ladder's weight?"
2. Relevant equations
T=F*l
ET=0
3. The attempt at a solution
I drew a picture of the ladder with one person in the front, and two people (x) distance away from the opposite end of the ladder. So, x is the distance from the two people to the far end, and 4-x is the distance of the front person from the two people.
Each holds one-third of the ladder's weight.
I decided I'd set the axis of rotation as the far end of the ladder and set up my equilibrium equation, so...
ET = (2/3w)(x) + (1/3w)(4-x) = 0
And then I kind of got stuck after fiddling around with my equation and getting, uh, nowhere. Tried to throw in a center of gravity equation and realized that wasn't really helping me. Any ideas?
Thanks,
Liz
Phys.Org News Partner Science news on Phys.org
Lemurs match scent of a friend to sound of her voice
Repeated self-healing now possible in composite materials
'Heartbleed' fix may slow Web performance
p21bass
p21bass is offline
#2
Nov9-10, 02:58 PM
P: 137
Try setting the person at the front of the ladder at 0.00m, and the other two people at x. Then take the moment about the front of the ladder.
Also, don't forget to take into account the weight of the ladder in your FBD.
PhanthomJay
PhanthomJay is offline
#3
Nov9-10, 03:05 PM
Sci Advisor
HW Helper
PF Gold
PhanthomJay's Avatar
P: 5,959
Hi, Liz, and welcome to Physics Forums!
Quote Quote by LizzleBizzle View Post
T=F*l
ET=0
Yes, but what's the distance of the front person from the far end?
Yes.
good idea
If you are summing moments about the far end, then you must determine the distance of each force from the far end. What is the distance from the front person to the far end? It is not (4-x). And you forgot to include the moment from the ladder's weight, the resultant force of which acts at the center of gravity of the ladder.
PhanthomJay
#4
Nov9-10, 03:09 PM
Sci Advisor
HW Helper
PF Gold
P: 5,959
Quote Quote by p21bass View Post
That's an even better idea
LizzleBizzle
#5
Nov9-10, 05:27 PM
P: 3
Ah ha. After a second cup of coffee, I gained a little more inspiration...thank you for the hints. So here's what I have so far, but maybe I have missed something:
I changed my point of rotation to the front end, as suggested. I accounted for the weight of the ladder.
I found the center of gravity to be (2/3w)(x) + (1/3)w(4) / w , which boils down to 2/3x + 1.3.
In this case, the force of the two guys in the back would rotate clockwise around the axis of rotation, so that value is negative, and the weight, which would rotate counterclockwise, is positive.
So...
ET = 0 = (2/3w)(4-x) - [(w)(2/3x + 1.3)]
0 = 2.6666w - 2/3wx - 2/3wx - 1.3w
1.3w = 1.3wx
x = 1 m?
This answer COULD make sense.
p21bass
p21bass is offline
#6
Nov10-10, 12:24 PM
P: 137
Huh? The center of gravity of the ladder would be at the midpoint - don't overthink it. And again, make the location of the two-person support as x. Then solve the equation for sum of moments.
Register to reply
Related Discussions
Rigid Body Equilibrium Question Introductory Physics Homework 6
Equilibrium Style Question involving a Weight Introductory Physics Homework 3
Equilibrium of a Rigid Body question Introductory Physics Homework 7
Ladder Question - Force of friction required to prevent ladder from slipping Introductory Physics Homework 4
Ladder question (Static equilibrium) Introductory Physics Homework 2
