Thread Closed
Young's modulus problem -- need a hint
Share Thread Thread Tools
Sep25-04, 12:14 PM   #1
There are two wires, one brass the other copper, both 50 cm long and 1.0 mm diameter. They are somehow connected to form a 1m length. A force is applied to both ends, resulting in a total length change of 0.5 mm. Given the respective young's moduluses of 1.3 x 10^11 and 1.0 x 10^11, I'm supposed to find the amount of length change in each section.
Apparently a variation of Hooke's law should be used here, such as F/A=Y(change in length/original length)
I'm stuck on how can I solve this with 2 unknowns (force and change in length)?
Regards
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Sep25-04, 12:54 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by redshift
Regards
Hello redshift! I'm going to rewritte your problem in terms of stress [tex]\sigma[/tex] (Pa) and unitary deformation [tex]\epsilon=\frac{L-L_o}{L_o}[/tex] where Lo is the original lenght. So that, the stress exerted is the same in each section of the wire:
Hooke's law: [tex] \sigma=E_t \epsilon_t=E_1 \epsilon_1=E_2 \epsilon_2[/tex] where "Et" (N/m^2) is the apparent Young modulus of the complete wire.
Compatibility of deformations: [tex]\bigtriangleup L=\bigtriangleup L_1 + \bigtriangleup L_2[/tex]
Then, you have three equations for three unknowns: Et, epsilon1 and epsilon2.
Hope this help you a bit.
You've got two unknowns for
Sep26-04, 12:33 AM   #3
I think I get it. Based on your equations, the ratio of the young's moduluses should equal the ratio of the individual increases, that is, 13/10 = L1/L2
Therefore, 10L1 = 13L2
Since, L1 = L2 = 0.5, then L1 = 0.5 - L2. Plugging this into the above gives 10(0.5 - L2) = 13L2, so that the increase of L2 (brass wire) is 0.21 mm.
Many thanks!
Thread Closed
Thread Tools
Similar Threads for: Young's modulus problem -- need a hint
Thread Forum Replies
Young's Modulus Introductory Physics Homework 9
Suspended hotel walkway (Young's modulus problem) Introductory Physics Homework 2
young's modulus Introductory Physics Homework 1
young's modulus Introductory Physics Homework 2
Young's Modulus Classical Physics 2
