Solving Acids & Bases Questions - pH, Ionisation Constant
The discussion revolves around solving problems related to acids and bases, specifically focusing on the ionization constant of propanoic acid, calculating pH, hydroxide ion concentration, and the behavior of picric acid as an acid-base indicator. The scope includes theoretical calculations and conceptual understanding of acid-base chemistry.
  • One participant suggests calculating the pH of a 1.0M solution of propanoic acid using its ionization constant and equilibrium expressions.
  • Another participant asserts that the ionization constant is equivalent to the equilibrium constant, prompting a discussion on the definitions and units involved.
  • Some participants express confusion over whether the ionization constant should be unitless or if it can have dimensions, leading to further debate on the nature of equilibrium constants.
  • A participant raises a question about determining the color of picric acid in a solution of pH 5, indicating uncertainty about the implications of the acid's ionization constant.
  • There is a suggestion that the initial concentration of picric acid is necessary to resolve the question about its color in relation to pH.
  • Another participant proposes that the color observed will be yellow due to the acidic medium, but this is based on assumptions about the ionization and concentration of the acid.
Participants express differing views on the relationship between ionization constants and equilibrium constants, with no consensus reached on whether the ionization constant should be unitless. Additionally, there is uncertainty regarding the color of picric acid at pH 5, with multiple interpretations presented.
Limitations include unresolved assumptions about the initial concentrations of acids, the dependence of equilibrium constants on specific reactions, and the implications of pH on color indicators.
Jack16
Hi People ,
I had a problem solving this question,could you please help me:D
The question:
a)The ionisation constant for propanoic acid is 1.26x10^-5 mol dm^-3.Calculate pH of a 1.0M solution
b)What is the hydroxide ion concentration of this solution?
c)Pocroc acid has an ionisation constant of 5.0x10^-3 mol dm^-3. It can act as an acid base indicator,the anions being red,and the free acid yellow.What colour will it show in a solution of pH 5?
Chemistry news on Phys.org
Hello,
Ionization constant is the same as equilibrium constant, I think. Write the equilibrium constant for propanoic acid's ionization with the help of its reaction, and find the unknown values. Omit some, and find hydrogen concentration, and then, pH value.
Hydroxide ion concentration is linked to hydrogen ion concentration with the equation, [tex]pH+pOH=14[/tex] for normal aqueous systems. Do something with this equation to learn the desired value.
Picric acid (2,4,6-trinitrophenol) can show the acidity, it's correct. Just find its ionization constants with this simplification, pic-H is picric acid, and pic- is picrate ion. You know the hydrogen concentration (pH). Just do it...
I don't think the ionization constant is the same as the equilibrium constant.
C2H5COOH <---> C2H5COO(-) + H(+)
At equil : [tex](1-\alpha)~moles~C_2H_5COOH~<--->~\alpha~moles~~C_2H_5COOH^-~+~\alpha~moles~H^+[/tex]
[tex]\alpha =~ ionization~(dissociation)~~constant[/tex]
[tex]K = \frac{\alpha ^2}{1-\alpha}[/tex]
Yes, Gokul, you are right. The [tex]\alpha[/tex] shows how much of it is ionized. I'd better freshen my knowledge. So ionization constant IS the same as hydrogen ion concentration, right? I made the error since it's expressed as [tex]mol.dm^{-3}[/tex], I thought [tex]\frac{\alpha^{2}}{(1-\alpha)}[/tex] has the same dimension, and just said it.
Yes, I too was concerned about the units. I'm sure that the ionization constant should be unitless.
So, either that is the equilibrium constant (and NOT the ionization constant) or there should be no units.
Can't have both.
The "ionization constant", "dissociation constant", Ka of such acids are simply special equilibrium constants...yes they are equilibrium constants.
I can do the first two but what about the 3rd?
I can't undertand this part?
Can't have both.
I thought units for [tex]K_p[/tex] and [tex]K_c[/tex] (equilibrium constants) change for each reaction
Eg:units for [tex]2NO_2<-->N_2O_4[/tex] is different from that for
[tex]C_2H_5COOH<--->C_2H_5COOH+H^+[/tex]
Dear poolwin2002,
You are right about changeable-unit-equilibrium constants. About picric acid's ionization, it is very simple, just look at the following reaction:
[tex]Pic-H \rightarrow Pic^-~+~H^+[/tex]
Here, we know the pH, that is, the hydrogen ion concentration, from the added acid. Then we may use the ionization constant's formula to obtain the initial hydrogen concentration from ionization of picric acid. But there may be a problem, that the initial picric acid concentration is not given. If the problem was correct, then the acidity is fully supplied by picric acid, and the initial concentration can easily be found. But then the problem is invalid, since the pH is given to be 5, and the solution is acidic. I'm confused indeed. Please, jack16, check the last question and post a message.
The Last Question...
c)Picric acid has an ionisation constant of 5.0x10^-3 moldm^-3.It can act as an acid base indicator,the anions being red,and the free acid yellow.What colour will it show in a solution of pH5?
Jack, you've seen our various discussions and concerns on this matter. What do you think ?
Hello, since GeneralChemTutor explained that they are different expressions about equilibrium constant, you can calculate the ionization constant as hydrogen ion concentration. Picric acid is dissolved in water at pH=5, add some hydrogen coming from pH=5.
Thanks but Sorry I was asking about red and yellow part
Hello,
Since the medium is acidic, I presume that yellow color will be formed. Just compare the two acidities; the first, I mean, coming from the ionization is even enough to produce yellow color. Then you put more enough to bring the acidity of pure water to pH 5. It's your task to find the final pH and the correct color.
Regards,
chem_tr (my 100th message :smile:)
