Limit of a sequence in an interval, defined to be different at each boundary.
The discussion revolves around the limit of a sequence defined by two different expressions for even and odd integers. The original poster expresses confusion regarding the notation and the semi-closed intervals involved in the limit evaluation.
  • Exploratory, Assumption checking
  • Participants discuss the concept of taking limits of sets and question how the original poster has defined this. There is uncertainty about the notation and its implications for evaluating limits.
The conversation is ongoing, with participants seeking clarification on the notation and the definition of limits in this context. Some guidance has been offered regarding checking course materials for similar definitions, but there is no explicit consensus on how to proceed with the problem.
The original poster notes a lack of clarity in the notation and expresses that they have only found the limits of the individual expressions without reaching a conclusion. There is an indication that additional information may be necessary to fully address the question.
tomelwood
I have to study the limit of a sequence which is defined as follows. I'm not looking for an answer, just a method of how to do it, or even what this notation means.
An = { ([tex]\frac{n^{2}}{3n^{3}+1}[/tex], [tex]\frac{4n^{2}}{n^{2}+1}[/tex] ] n even
An = { ([tex]\frac{n^{2}}{6n^{2}-4}[/tex], [tex]\frac{2n^{2}+3}{4n^{2}}[/tex] ] n odd
Study if the limit as n--> [tex]\infty[/tex] exists.
It may not be very clear from the latex code, but the terms are both in semi closed intervals (__ , __ ] which is mainly what is confusing me!
All I have done so far is find the limits of each of the four expressions, but this hasn't really helped. Any pointers would be useful, or an example of a similar question.
Thanks.
You seem to take the limit of sets... How have you defined this?
To be honest, I have never seen this notation before, so have really no idea what I am doing. Taking limits of each of the four expressions and seeing what they tended to seemed the only thing I could do. Is there a way to do this type of question??
well; all depends on how that limit is defined. Maybe you should check your course to see if there's nothing like that in there... and if you don't find anything, then I'm afrain that you don't have enough information to solve the question :cry:
