Kinematics one dimension. help
The discussion revolves around kinematics in one dimension, specifically focusing on two cars accelerating and their relative motions. The original poster presents a problem involving two cars, one accelerating from rest and the other starting from a position behind, seeking to determine the distance required for one car to catch up to the other.
  • Participants explore the relationship between time and distance for both cars, questioning how to incorporate the initial distance between them. There are attempts to set up equations based on acceleration and initial velocities, with some participants expressing confusion about the implications of constant speed.
Some participants have made progress in formulating equations to relate the distances traveled by both cars. Others have raised questions about the definitions of terms like constant speed and initial velocity, indicating a mix of understanding and uncertainty. A few participants have suggested using graphical methods to visualize the problem, while others are considering algebraic approaches.
There are indications of confusion regarding the application of kinematic equations, particularly in distinguishing between constant speed and acceleration. The original poster also notes a lack of clarity on how to incorporate the initial distance of 20 meters into their calculations.
saiyajin822
kinematics one dimension. help!
hi I've had a lot of trouble with this problem and i hope someone can help me.
Car B starts from rest and accelerates at 2.00m/s^2 along a straight road. Car A starts from rest at the same instant 20.0 m behind car B and accelerates 3.00 m/s^2. How far must car A move in order to catch car B? What will be the speeds of car A and car B?
im pretty sure that the time is equal in both cases so t_a=t_b. but it is also asking for distance, and i don't see any equation that requires only acceleration and initial velocity. i have no idea where that 20 m behind goes to.
Can someone explain this problem to me and show me how to do it? I am very confused. :confused: Thanks!
ok so far i got Da(distance of A)=20+Db and Db=1/2at^2. do u just plug in the values and set them equal?
nevermind i finally figured the problem out. but i have another one I am having trouble with.
Car B is moving at a constant speed of 25m/s along a straight road. Car A starts from rest and moves in the same direction when B is 20.0 m ahead. If A accelerates at a rate of 5 m/s^2, how far must it travel in order to catch B? How long will it take? How fast will A be traveling when it catches B?
Does constant speed mean initial velocity?
can someone explain to me how to do this?
thanks
Start by developing an equation for the speed of A relative to B (pretend B is stationary). Can you take it from there?
so i should take that car B has an acceleration of 0? I am still confused on what constant speed is - does that mean average velocity, final velocity, or initial velocity?
ok i counted the 25m/s as initial velocity and the acceleration 0 for car B. I set car A and B equal using the equation d=vi(t)+1/2(a)(t)^2.
so, 1/2(5)t^2=20+25t
then , 2.5(t)^2-25(t)-20=0 and use the quadratic formula? is that it?
I don't like using formulae. Think of a velocity-time graph. The line representing the movement of Car B will have a gradient of 2. The line representing the movement of Car A will have a gradient of 3. The distance moved by each car is the distance underneath each line.
When Car A catches up with Car B, it will have traveled the same amount of time as Car B, but it will have traversed an extra distance of 20m.
In the graph, because the area underneath each of the lines is a triangle, we can calculate
1/2 x t x 2t + 20 = (1/2 x t x 3t)
t^2 + 20 = 3/2t^2
20 = (t^2)/2
t^2 = 40
t = 6.32455532
  • · Replies 34 ·
