The discussion revolves around calculating the work or energy involved in lifting and moving a 90 lb bag of shingles. Participants explore the physics concepts of work, energy, and power in the context of lifting and transporting the bag over specified distances and times.
- Exploratory
- Technical explanation
- Conceptual clarification
- Debate/contested
- Homework-related
- One participant asks for help calculating the work involved in lifting a 90 lb bag of shingles to a height of 6 feet and moving it to a scaffold.
- Another participant proposes that the work done in lifting is 108 ft*lb/s and the work done in moving is 15 ft*lb/s, but expresses uncertainty due to confusion with units.
- A different participant clarifies that work is defined as force times distance, emphasizing that time is not a factor in calculating work and that only the change in elevation matters.
- One participant acknowledges the confusion between work and power, suggesting that the original question might have been intended to ask about energy used rather than work.
- Another participant notes the complexity of determining work done by the human body, highlighting that it varies based on individual metabolism and other factors, while still relating it to the potential energy change formula.
- The original poster reflects on their initial confusion and clarifies that they were seeking to understand the energy required to lift the bag, indicating a desire for a straightforward solution.
Participants express differing views on the definitions and calculations of work, energy, and power. There is no consensus on the exact values or methods to calculate the work involved, and the discussion remains unresolved regarding the complexities of human energy expenditure.
Participants mention the importance of distinguishing between work and power, as well as the variability in energy expenditure among individuals, which complicates the calculations. There are also references to unit conversions and the need for clarity in definitions.
