Ways to make a dollar with variable denominations
  • Context: Undergrad
  • Thread starter Thread starter soandos
    Variable
The discussion revolves around the problem of determining the number of ways to make a dollar using coins of various denominations (1, 4, 7, 15, and 33 cents). Participants explore theoretical approaches, mathematical reasoning, and computational methods related to this combinatorial problem.
  • One participant asks how many ways there are to make a dollar with specific coin denominations and inquires about a general formula for such problems.
  • Another participant suggests that this problem resembles the knapsack problem and expresses doubt about the existence of an easy formula, indicating that checking every possibility may be necessary.
  • A reference is made to a book that discusses using generating functions to solve similar problems, suggesting that the same methodology could apply here.
  • One participant shares a method involving Taylor expansion to find coefficients related to partitioning a dollar into subsets of specified coin values, asking for clarification on this approach.
  • Another participant notes that the problem is related to the knapsack problem but emphasizes that the goal is not to maximize value but to achieve a specific total.
  • A participant introduces the concept of multinomial coefficients and discusses how they relate to counting combinations in polynomial expansions.
  • There is a mention of a polynomial expression that could be used to find the number of ways to make change, with some participants questioning the accuracy of the coefficients used in the expressions.
  • Several participants share their results from calculations using the proposed methods, noting discrepancies in their findings and suggesting that errors may exist in their implementations or assumptions.
  • One participant proposes writing a program to generate and count combinations of coins to verify the results obtained through mathematical reasoning.
Participants express differing views on the methods to solve the problem, with some supporting the use of generating functions while others prefer recursive approaches or computational methods. There is no consensus on the correct number of ways to make change, as participants report varying results.
Some discussions involve assumptions about the use of specific coin denominations and the accuracy of mathematical expressions. There are also unresolved questions about the correctness of coefficients in polynomial expansions and the implementation of proposed algorithms.
This discussion may be of interest to those studying combinatorial mathematics, algorithm design, or anyone looking to explore methods for solving problems related to partitioning and counting combinations of discrete values.
soandos
How many ways are there to make a dollar using coins of denominations of 1,4,7,15,33 cents each?
is there a formula that can generalize this for any set of given denominations?
This is the knapsack problem. I doubt that there is an easy formula for this. As for your first question, I fear that you'll have to check every possibility :cry:
In Graham, Knuth & Patashnki's "Concrete Mathematics" in chapter 7 shows how to use generating functions to solve problems exactly like this. Their example uses pennies, nickels, dimes, quarters and half dollars but the same steps should apply to your problem.
I saw this: "Take the taylor expansion of 1 over (1-x)*(1-x5)*(1-x10)*(1-x25)*(1-x50)*(1-x100), and jot down the coefficient of x100. This is the generating function for the ways to partition 100 into subsets of size 1, 5, 10, 25, 50, or 100, so there are 293 ways to make change for one us dollar." on answers.com, but i got a massive co-efficient for the Taylor expansion about x=1.
Is this what you were talking about?
and if so, can you please explain it?
It seems related to the knapsack problem, there there is no issue of weights, and the value is not to be maximized, but equal to a given number.
Actually, this is also a variation on the idea of the multinomial coefficients:
when you do (a+b)^2 =a^2+2ab+b^2 , the 2 in 2ab is the number of ways
you can get a term with one a and one b in an expansion (a+b)(a+b): you
can choose the a in two ways, then the second term is determined.
Same for (a+b)^n =(a+b)(a+b)...(a+b) :
to see how many terms a^kb you can get ( 0<=k<=n, of course) : you can
select k a's out of the n possible ones in the product in nCk ways. This is
another way of seeing the binomial coefficients.
Now expand to the case of a multinomial ( x^1+x^10+...+x^25)^100
How many terms will add up to 100.?
(x + x^5 + x^10 + x^25 + x^50)^100. the x^100 co-efficient is one...
unless i messed up.
The description of how to understand and use generating functions in Graham, Knuth & Patashnki's "Concrete Mathematics" to solve this problem is probably too long to include here. It does show that there are 292 ways of making change for a dollar, but they do not include a dollar coin, so it is one less than your 293 ways.
If you find yourself interested in problem solving I highly recommend buying a copy of the book. There are lots of things you can learn from it. See if you can get a later edition and a later printing because, unlike Knuth's other books, there were a variety of small errors in the earlier versions of the book. There are errata lists on the net if you get an earlier version and you can go through and mark up your copy.
I only wish I could say that I had mastered a substantial fraction of all the material in the book or that I had been able to sit in the back of their class and learn the material from them.
Some observations that may be helpful:
1. The number of ways to make change for a dollar with coins of value 1, 4, 7, 15 and 33 is the same as the number of ways to make change for a dollar or less (including an amount of zero) with coins of value 4, 7, 15 and 33.
2. If you're doing this by pencil and paper, the most efficient method may be a recursive approach. I.e., you know there can only be 0, 1, 2, or 3 coins of value 33. So find the number of ways to make change for 1, 34, 67, or 100 cents with coins of value 1, 4, 7, and 15. Keep breaking the problem into smaller cases similarly. You can probably figure out how to organize your work in a table and work from the bottom up instead of the top-down (recursive) approach.
3. If you have access to a computer algebra package, consider the polynomials
[tex]P = 1 + x^{33} + x^{67}[/tex]
[tex]Q = 1 + x^{15} + x^{30} + \dots + x^{90}[/tex]
[tex]R = 1 + x^7 + x^{14} + \dots + x^{98}[/tex]
[tex]S = 1 + x^4 + x^8 + \dots + x^{100}[/tex]
Expand PQRS. The answer to the problem is the sum of the coefficients of the powers of x less than or equal to x^100 , by Observation 1. Or you could do this with pencil and paper, retaining only powers of x less than or equal to x^100 as you go along.
why is [tex] P = 1 + x^{33} + x^{67}[/tex]
as opposed to [tex] P = 1 + x^{33} + x^{66}[/tex]
Oops, I should have written
[tex] P = 1 + x^{33} + x^{66} + x^{99}[/tex]
I got 824. Did i implement it correctly?
Using his PQRS technique I get 823 which is the sum of 1, 1, 1, 1, 1, 1, 1, 2, 1, 1, 2, 1, 1, 2, 2, 1, 1, 2, 2, 2, 2, 3, 2, 2, 3, 3, 3, 3, 4, 3, 3, 4, 4, 4, 4, 5, 5, 4, 5, 6, 6, 5, 6, 7, 6, 6, 7, 8, 7, 7, 8, 9, 8, 8, 10, 10, 9, 10, 11, 11, 10, 12, 12, 12, 12, 13, 14, 13, 14, 15, 15, 15, 16, 17, 16, 17, 18, 18, 18, 19, 20, 20, 20, 21, 22, 22, 22, 24, 24, 24, 24, 26. If you check off your coefficients against mine maybe you can find that you missed one, I missed one or we both missed something.
As a check I use his PQRS on nickels,dimes,quarters,halves and get 292 which matches the above mentioned value.
As a check, you might find it interesting to write a program which actually generates and counts the combinations. Something like
Code:
goal = 100
nways = 0
for x33 = 0 to floor(goal / 33)
  for x15 = 0 to floor((goal - 33 * x33) / 15)
    for x7 = 0 to floor((goal - 33 * x33 - 15 * x15) / 7)
      for x4 = 0 to floor((goal - 33 * x33 - 15 * x15 - 7 *x7) / 4)
         nways = nways + 1
  • · Replies 28 ·
