New Reply
Optimal mass distribution for maximal gravitational field
Share Thread Thread Tools
Nov12-10, 12:36 PM   #1
Suppose that one is given a lump of clay of total mass M and constant density. Let P denote a particular point in space. In what way should one shape and position the clay so that the gravitational field in point P is maximum possible? It is assumed that the clay stays in one piece during the shaping.
2. Relevant equations
Newton's law of gravity
Variational principle (?)
3. The attempt at a solution
I don't know if this problem has an obvious and trivial solution, but I'm thinking along the lines of variational principle. Let P be the origin of coordinates with z axis pointing in the direction of the gravitational field. Then we have the following equations
[tex]F=G \rho\int_{\mathcal{V}}dV\frac{\cos \theta}{r^2}[/tex]
[tex]M=\rho V[/tex]
Can I maximize the force by varying the volume of integration using the second equation as a constraint?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
New Reply
Thread Tools
Similar Threads for: Optimal mass distribution for maximal gravitational field
Thread Forum Replies
Symmetry of mass distribution producing radial gravitational force field Classical Physics 11
Gravitational field has mass??? Special & General Relativity 5
the Higgs field: so gravitational field by itself cannot confer mass? High Energy, Nuclear, Particle Physics 4
Equilibrium temperature distribution of ideal gas in homogeneous gravitational field Classical Physics 4
