Einstein's Cosmological Constant
The discussion revolves around the value of the cosmological constant (ecc) and its measurement, particularly in relation to dark energy and critical density. Participants explore various reported values, their sources, and the implications of uncertainty in these measurements.
  • Some participants mention a commonly used value of 70 percent for the cosmological constant, while others note that a closer fit to data is 73 percent.
  • There is a discussion about the critical density (rho-crit) and how the cosmological constant can be expressed as a percentage of it.
  • One participant emphasizes that they do not have a preferred value but report what is commonly used, referencing the WMAP instrument for measurements.
  • Another participant raises the possibility of an 80 percent value, describing it as arbitrary and questioning the difficulty of obtaining a definitive answer.
  • Participants reference various sources for values and measurements, including works by Michael Turner and Charles Lineweaver, as well as WMAP reports.
  • There is mention of error bars in measurements, specifically noting that the current value is 0.73 ± 0.04, indicating uncertainty in the measurements.
  • One participant expresses confusion about the confidence in the reported values, acknowledging the expertise of those publishing the data.
Participants express varying values for the cosmological constant, with no consensus on a definitive figure. There is acknowledgment of uncertainty in measurements, and multiple competing views remain regarding the accuracy and implications of these values.
Participants highlight the limitations of current measurements, including the dependence on specific definitions and the unresolved nature of certain parameters. The discussion reflects ongoing exploration rather than settled conclusions.
Finger Painter
recently i heard a prominent english physicist using 70 as his value for ecc. what value do you like and where did you get it from?
Space news on Phys.org
70 what?? In other words, what units?
70 percent is a common way of expressing the generally agreed-on size of it
there is a widely understood energy density called
the critical density (written "rhocrit")
and the ecc. can be viewed as the density of dark energy or vacuum energy
so it can be expressed as a percentage of rho-crit
and the closest fit to the data is currently 73 percent or 0.73
but many people just say 0.7 or 70 percent because at this
point approximate magnitude is what matters so it sounds too
finicky and overprecise otherwise
I personally don't "like" any particular value, I just report what
figure they are using. It is a parameter that is measurable and the best determinations of it come from an instrument called WMAP that is orbiting the sun in a somewhat larger orbit than the earth's. I must say I like the way the ecc. is measured!
Where do you get the 0.73 (or the approximate 0.7) from?
there are a ton of sources for that, many of them online
Michael Turner "Making sense of the new cosmology"
http://arxiv.org/astro-ph/0202008
Charles Lineweaver "Inflation and the Cosmic Microwave Background"
http://arxiv.org/astro-ph/0305179
Ned Wright's online cosmology tutorial
There is a report by Bennett et al of WMAP results that gives
the latest rundown on measurements of a bunch of cosmological
parameters including this one. If you want URLs ask, this is just a sampling
thanks for your replies. I've also heard 80 as a value, but it does seem a bit arbitrary. until it is proven, i guess maybe that's all we can expect. will it be difficult to get a definitive answer?
For a look at over a dozen parameters, including this one, currently measured values with error bars showing uncertainty see Table 1 on page 32 of Charles Lineweaver "Inflation and the Cosmic Microwave Background"
That is as of May 2003. As far as the cosm. const goes you can see from the table that the error bar currently looks like this
ΩΛ = 0.73 ± 0.04
That means that experts responsible for publishing the data are betting their professional reputations on future improved observations by their colleagues never getting out of the bracket
0.69 - 0.77
I would guess that future measurements will likely
cluster about 0.73 but there is a margin of error and it is currently plus/minus 0.04
Frankly I don't entirely understand where the certitude comes from but they are the pros and not me and I respect the work to the extent I'm able to judge it, so I accept the data
The WMAP project is pretty amazing and that is where the data in Table one comes from---a recent WMAP report. Have a look and form your own opinion
  • · Replies 18 ·
  • · Replies 19 ·
10K
  • · Replies 153 ·
14K
  • · Replies 26 ·
  • · Replies 0 ·
