Determining Force for Toppling 30" Round Table
The discussion focuses on calculating the force required to topple a 30" diameter round table made of medium density fiberboard (MDF) with a density of 39 lbs/ft³. The table has three aluminum legs, and the analysis suggests simplifying the problem by considering torque around the midpoint between two legs. The key insight is that the force must be sufficient to raise the table's center of mass above the pivot line formed by the legs, leading to a state of equilibrium where any additional force will cause the table to topple.
  • Understanding of basic physics concepts, particularly torque and equilibrium
  • Familiarity with the properties of materials, specifically medium density fiberboard (MDF)
  • Knowledge of force calculations and how they apply to rigid bodies
  • Basic geometry related to circular objects and their centers of mass
  • Research torque calculations in physics, focusing on rigid body dynamics
  • Study the properties and applications of medium density fiberboard (MDF)
  • Explore equilibrium conditions in mechanical systems
  • Learn about the effects of weight distribution on stability in furniture design
Engineers, furniture designers, physics students, and anyone interested in the mechanics of stability and force application in physical objects.
kopplaw
I am trying to determine how much force is necessary to make a round table topple over, or what information I need to make such a determination. The table is 30" in diameter and 1 1/4" thick, made from medium density fiberboard (MDF). The MDF has a density of 39 lbs/foot3. The table has three legs, equidistant from each other, placed at the edge of the table. The legs are made of aluminum, but I do not know their weight or exact size. The legs are 22 1/4" in height and are secured directly to the bottom of the table.
Is there a way of roughly calculating how much weight would be required to topple the table if the weight were placed precisely between two of the legs at the edge of the table?
Interesting question. I haven't actually thought about something like this before but here's a go at it:
Since the legs are made of aluminum you might as well just discard them in the calculation. Look at the table from the side in such a way that you only see two legs (one leg is obstructed from view I see this happening on the left side in my mind). You notice the edge of the table (again on the left side in my mind) extends (1-sqrt(3)/2)*15" farther than the leg. Also since the table is so thin just disregard the table thickness and condense it to a line from the side. I hope I gave enough information that you can reduce it to a simple torque problem. That should give a rough estimate
Try calculating the torque about a convenient point e.g. on the floor at the midpoint joining one pair of legs at their bases. Imagine pulling from the edge of the table perpendicularly to the line on the floor. There are now two forces contributing to the torque - one from the applied force and the other from gravity acting effectively through the center of mass of the table.
There are two stages. When the first threshold is crossed the odd leg will no longer exert any force on the floor so we no longer need to consider it. As more force is applied the table will rise but will fall back to its starting position if we release the force. If we pull hard enough so that the torque pulls the table up to a point where its center of mass is directly above the line on the floor then we will have reached a state of equilibrium where the table could fall either way if the applied force is released. This is the force you're looking for since any additional force will cause the table to topple - away from its starting position.
  • · Replies 25 ·
11K
